Sponsored by: Real Truck
Center caps
Old Aug 11, 2009 | 06:45 PM
brsexton's Avatar
brsexton
Center caps
I was wondering how to remove the chrome center caps on the wheels of my 99 F250 SD? Mine has the alloy wheels with a plain center cap. This isn't the cap that covers the lugs. I can't figure out if I need to take the wheels off to remove the cap or just try to pry it off. Thanks in advance for any info.
Old Aug 11, 2009 | 07:40 PM
bayou barataria's Avatar
bayou barataria
You have to remove the wheel on a lot of them.
Old Aug 13, 2009 | 02:23 AM
schmidt64's Avatar
schmidt64
If the cap isn't the type that grabs onto the lug nuts then it most likely pushes thru the center of the wheel from the inner hub surface and, yes, would require the wheel to be removed.
Old Aug 13, 2009 | 09:08 AM
brian42's Avatar
brian42
Veteran: Navy
x3. Remove the wheel and pop them out from behind.
ForeverFixing
Dec 13, 2017 06:21 AM
comptonbranch
Nov 10, 2017 06:14 PM
batesd
Nov 30, 2016 09:47 PM
bg in mo
Nov 29, 2016 12:51 PM
Azuretruck
Oct 2, 2016 08:14 AM
