well i got my truck running and lost the key to the locking gas cap for the gas cap behind the cab can new keys be made for these caps and how do you get the caps off without breaking things?
OMG Thread Vader. ...Nevermind breaking things... it's causing a spark while attempting to remove it that should be of concern... No drills or steel pry tools. Brass tools would be preferred.
Consider a locksmith lest ya wanna blow your azz up to kingdom come.
I would unfasten neck from the inside the cab and withdraw the filler neck from the body seal to work on it elsewhere. In the end, it may mean a replacement neck and cap.
I found a brand new locking cap at the J/Y its a stanz brand, and the key from my old gas cap is also a stanz, the keys are almost identical, ether one opens both gas caps.
Hahaha HIO....thread Vader I thought the same thing when I seen the name under the thread title. I'd remove the filler tube from the tank like mentioned above so no sparks ignite more problems then just a lost key. Also you could take it to a lock smith and maybe save acouple bucks from him needing to make a house call.
When I saw the name I thought the same thing. At which point I was going to suggest using a torch to get the cap off.
