C-6... Raising shift points...?
Old Aug 14, 2004 | 02:11 PM
CrazyAirman's Avatar
CrazyAirman
Hey guys, is it possible to raise the part throttle shift points on my C-6?
Its a 74 F100 4x4, 390. I ask because it seems to shift into 3rd before
20 mph, unless I am more aggressive with it, and then I get the wrath of my Locker(which is cool sometimes, but not all the time) Anything I can do? Thanks!
Old Aug 14, 2004 | 05:57 PM
rclarke's Avatar
rclarke
C6 shift points are easily changed. If the vacumn modulator has a screw inside the tube that the vacumn hose is hooked to, just screw the adjuster screw in a little. 1 turn should raise the shift points about 5mph or so.
If there is no adjusting screw in the modulator. There is a small rod behind the modulator. Remove the modulator (you might lose a little fluid) remove the rod, buy or make a slightly longer rod. The rod kits probably are not available anymore but a piece of 1/8 welding rod will work. Make it longer by 1/16" or so and try it. Longer will make the transmission shift later, shorter is earlier.
Old Aug 15, 2004 | 02:23 AM
CrazyAirman
Thanks!! I'll take a look at the modulator 1st thing in the morning, I never thought to see if it was adjustable....
Old Aug 15, 2004 | 06:39 PM
mhg's Avatar
mhg
if not adj. its cheap to buy a new one that is
derherr65
Mar 16, 2006 10:00 PM
DuckRyder
Sep 14, 2003 08:10 AM
frank_65
Dec 10, 2002 08:12 PM
BroncoScott
Nov 17, 2002 07:06 PM
Jim McCarty
Jun 28, 2002 05:30 PM
