resurfacing driveway
Old Aug 12, 2004 | 09:58 PM
JasonAppletree's Avatar
JasonAppletree
Has anyone resurfaced/resealed their driveway before? I'm planning on resealing my asphalt driveway tomorrow. I've prepped it already, filled cracks, swept and hosed it down, but there is some sand still remaining. Is that good enough? Any input is appreciated.
Jason
Old Aug 12, 2004 | 10:00 PM
Sn0wMan's Avatar
Sn0wMan
Tear it out and get cement.
Old Aug 12, 2004 | 10:56 PM
TrunkSlammer's Avatar
TrunkSlammer
Thumbs up
With the note that the asphalt companies fix would be more perminate, in the mean time asphalt crack filler and cold process asphalt or emulsufied asphalt (to fill the ruts) and asphalt sealers are available at most concrete/masonry supply yards.
The crack filler is a viscious liquid (basically a form of emulsified asphalt). The surface must be dry, with no threat of rain or snow for a couple of days, before you can begin.
The instructions are on the container, however, if the cracks are wider, masonry sand can be used as a gap filler in conjuction with the crack filler. Pour in a base coat, then sand, then a top coat, then scatter a little sand on top.
Cold process asphalt comes in sacks. Again, the surface must be dry, but rain or snow afterward is not such a big concern. Typically the asphalt in the sacks is compact and must be broken into a finer granular form with a pick or shovel. Afterward it's spread into the hole in 2" layers and compacted with heavy pressure (hand pounding with a 4x4, a plate or pogo compactor [rentals], water filled landscaping roller, or running over a board with a heavy vehicle).
Emulsufied asphalt is a viscious liquid. Again, the surface must be dry and rain or snow is a problem to avoid. The following assumes a deep hole repair. Thus, adjust things to suit the need. Remove the old asphalt and put down a 4" to 6" base of 1/2 compacted stone. Apply emulsfied asphalt at the rate of 1 1/2 gallons per square yard. Allow this to cure for 24 hours. Next reapply emulsified asphalt at the rate of 1/4 gallon per square yard, then spead sand or pea gravel at the rate of 30 pounds per sqaure yard, then immediately afterward roll with a heavy roller. Rolling must be done before the emulsion sets. Let cure for 24 hours. If it's not smooth enough, reapply emulsified asphault and reroll.
Asphalt sealer is a coal tar emulsion, covering about 100 square feet per gallon. The sealer will help to prevent staining from oil and gasoline and protect the asphalt from weather damage.
Old Aug 15, 2004 | 03:00 PM
websthes's Avatar
websthes
Jason
you can never sweep all the sand off with a broom... the best is to clean it with a powerful leaf blower
Old Aug 15, 2004 | 06:19 PM
killerklown's Avatar
killerklown
I know when I was working with blacktop, before we filled crack we blew them out with compressed air, and only filled small cracks with the cold filler.
If I remember correctly when we were spreading on the top sealcoat, it had silica sand mixed with it.
Old Aug 16, 2004 | 08:47 AM
websthes's Avatar
websthes
you have to clean out the cracks first or you'll be sweeping forever. use a metal hook to dig the dirt out of the cracks, then a wire brush. this will help the crack filling product stick but it also stops you from turning up more dirt when you pass the broom over the cracks. but don't go so deep that you disturb the foundation and pull up pieces of asphalt. it might be as little as 1" thick in spots. just enough to get the dirt out from between the cracks.
ford2go
Dec 16, 2012 03:45 PM
Nitramjr
36
Jan 11, 2011 03:58 PM
scole250
15
Dec 22, 2006 07:52 AM
88grandmarquis
Mar 28, 2006 10:38 AM
e1p1
13
Dec 5, 2005 01:56 PM
