How do you make snow?
Old Dec 20, 2006 | 01:18 PM
scole250's Avatar
scole250
It hasn't snowed here for couple years, not more than a few flurries anyway. If it gets cold enough, I want to make some snow! Can you make snow by using a power washer to spray cold water? If so, how cold does the water and outside temp need to be?
Old Dec 20, 2006 | 01:25 PM
ddrumman2004's Avatar
ddrumman2004
From what I remember about snow, each snow crystal forms around a particle of dust. I doubt spraying water in the air would do it. If the air is cold enough, ice will form.
Snow forming is complex in that the crystals fall and rise and build up enough "body" to overcome garavity and wind and thus fall to earth.
Maybe someone else with more knowledge will jump in here.
For the record, I would love to see at least 6 or more inches of snow fall here as we haven't had any in a few years.
Old Dec 20, 2006 | 01:47 PM
pitrow's Avatar
pitrow
snowflakes are, as drumman said, ice crystals. To form them I assume you would need water vapor in the air, not just droplets.
I think any form of spraying water would just form either hail or freezing rain, since you already have droplets of water. Maybe if you could find a way to truely atomize the water molecules and you had a way to keep them seperate until crystals formed you might be able to do it. I would assume at that point you would need air that is below 32 degrees and water that is right at the freezing point, say 32.1 degrees.
Old Dec 20, 2006 | 01:55 PM
fred_79f250's Avatar
fred_79f250
Snow forms when you have the right combination of temperature and relative humidity. So just being below freezing isn't enough. But under the right conditoins, you might get a little snow from your jet washer....
Modern snow-making equipment at ski-resorts actually mix air into the water as it's sprayed, to get fluffier or wetter snow.
You can buy snow making equipment intended for home owners, but they're thousands of dollars.
Old Dec 20, 2006 | 01:58 PM
ddrumman2004
Good reading here!
Scroll down and read.
Old Dec 20, 2006 | 02:04 PM
teepee542's Avatar
teepee542
go to this site
http://backyardblizzard.com/?gclid=C...FQcLGgod4Tc9Ow
If you search google you can find sites that have instructions on making you own with a pressure washer and an air compressor.
Old Dec 20, 2006 | 02:41 PM
wlihntr's Avatar
wlihntr
you want snow!!!! i got about 2 feet in my front yard and its still falling
Old Dec 20, 2006 | 02:53 PM
jroehl's Avatar
jroehl
Pressure washer, air compressor, some well-placed fittings, appropriate wet-bulb temperature, and you're good to go. Here's a site with some generic plans (and some fittings that are helpful):
http://www.snowathome.com/
Jason
Old Dec 21, 2006 | 10:01 AM
04F150SC's Avatar
04F150SC
I heard about that snow in Colorado, man that is some storm. But, I heard it was supposed to warm up later in the week in Colorado. Bad news if you like snow!
Old Dec 21, 2006 | 10:25 AM
OSin86's Avatar
OSin86
If it's cold enough all you have to do is toss a cup of HOT water in the air and it will freeze before hitting the ground.
Old Dec 21, 2006 | 01:38 PM
hawk's Avatar
hawk
http://www3.whdh.com/news/articles/extra/1887/
Old Dec 21, 2006 | 07:10 PM
Mil1ion's Avatar
Mil1ion
I just made... and sent .....a whole crapload of snow through the American midwest.
Read this thread
https://www.ford-trucks.com/forums/5...some-snow.html
Checkout Colorado and a little east.
You'll have to wait your turn
Old Dec 22, 2006 | 12:02 AM
olfordsnstone's Avatar
olfordsnstone
When I want to make snow, I just make plans in the winter that entale a warm day and beer. Sure as crap, it'll snow.
Old Dec 22, 2006 | 12:35 AM
websthes's Avatar
websthes
well that sounds pretty handy. and you wouldn't have to get any on the car or in the driveway
Old Dec 22, 2006 | 01:38 AM
Torque1st's Avatar
Torque1st
Posting Legend
You could try one of those mist generators that are used on fans.
Like Item# 250737 at http://www.northerntool.com/
I have seen some units that were combined with a high velocity fan and sprayed a column of mist from the center of the fan also.
