1978 - 1996 Big Bronco
Recomendations, manual hub conversion '94
Old Sep 18, 2004 | 07:02 AM
subdude's Avatar
subdude
I Converted My 89 (5 bolt hubs) to warn Premiums, No conversion kit needed. It also tells you right on the Warn Website http://www.warn.com/truck/hubs/premium_hubs.shtml in the Application Notes
once you select your vehicle that only the three bolt jobs need the conversion kit.
Quote from Warn site "Replacing Automatic 3 Hole Cap With Manual; Use Correct Spindle Nut Kit "
Old Sep 24, 2004 | 10:16 AM
gatorx1's Avatar
gatorx1
5 bolt/screw ??
the 3 or 5 bolt/screw for the auto hubs, . . . are these the screws on the auto hub?? just wondering if i need the conversion kit
Old Sep 24, 2004 | 10:26 AM
skelator's Avatar
skelator
yes, we are talking about the bolts on the front that you can see.
Old Nov 7, 2004 | 12:00 PM
skelator's Avatar
skelator
ok, did the swap, put in mile markers, my theory on this is that if mile marker's products are good enough for the military then they are good enough for me. took me about 45 min, and just for a little FYI if you are only pulling out the hub mechanism you dont have to lift the truck off of the ground or take the wheel off.
jleo
Jan 1, 2023 10:24 PM
Skatermike24
Jun 10, 2017 02:25 PM
DoeyDooper
1983 - 2012 Ranger & B-Series
Feb 14, 2017 10:30 PM
xc4jokestomper
Dec 27, 2011 10:38 AM
lallen
Offroad & 4x4
Mar 6, 2001 04:11 AM
