5 bolt auto hubs to manual conversion?
Old 04-10-2016, 11:54 PM
jleo
jleo is offline
jleo is starting off with a positive reputation.
My truck is a 1994 F150 with automatic locking hubs, these hubs have 5 bolts holding the hub on.
I want to replace these with manual locking hubs.
Do I need a conversion kit to do this or is the conversion kit just to convert from auto hubs with 3 bolts?
Old 04-11-2016, 12:36 AM
TC-Countryboy's Avatar
TC-Countryboy
TC-Countryboy is offline
TC-Countryboy is starting off with a positive reputation.
Can't say for sure on your Dana 44 hubs, but the Dana 50 hubs on an 94 F250 that I have had the 5 screw auto hubs and while everyone even service at Mile Marker said that a conversion kit was required, it had the same internal nuts as was in the conversion kit that I ordered.
Old 04-11-2016, 09:08 AM
BLDTruth's Avatar
BLDTruth
BLDTruth is offline
BLDTruth is starting off with a positive reputation.
Pretty sure the 5-bolt have the proper spindle nuts, so you won't need the conversion.
Old 04-11-2016, 07:54 PM
f1504x4driver's Avatar
f1504x4driver
f1504x4driver is offline
f1504x4driver has a good reputation on FTE.f1504x4driver has a good reputation on FTE.
It depends on the manufacturer of the hub. Some such as WARN require a conversion kit, others do not. I replaced my auto hubs with Superwinch hubs 18 years ago and they have performed flawlessly. Direct swap
Old 04-11-2016, 11:31 PM
animator's Avatar
animator
animator is offline
animator is starting off with a positive reputation.
All you need is a set of Warn (or insert your mfg of choice here) hubs for your Dana 44. Nothing else is needed.
It is literally a 10 minute job.
Old 04-12-2016, 08:44 AM
jleo
jleo is offline
Thanks for the replies. I have ordered Milemarker 104 premium hubs. I will report back with how it goes.
Old 04-12-2016, 11:39 AM
Nothing Special's Avatar
Nothing Special
Nothing Special is offline
Nothing Special is a name known to allNothing Special is a name known to allNothing Special is a name known to allNothing Special is a name known to allNothing Special is a name known to allNothing Special is a name known to all
At least some auto hubs require a different spindle nut. And that spindle nut gets in the way of some manual hubs. So swapping from autos to manuals isn't always quite that simple. It's not a lot worse, just swapping the spindle nuts, which are right behind the locking hubs, so nothing else needs to be done. But a lot of people will choose to relube the wheel bearings since they're in to that point already.
Old 04-12-2016, 11:44 AM
BLDTruth's Avatar
BLDTruth
BLDTruth is offline
The 5 bolt auto hubs don't need the spindle nut conversion.
The 3 bolt auto hubs need the spindle nut conversion - these show up in mid-94 and later Bronco/F150's. They have the proprietary spindle nut that is held in place with a keyed washer.
Just an FYI for anyone who searches for this later.
http://www.supermotors.net/registry/2742/12739
Gunnerboy
1978 - 1996 Big Bronco
08-22-2017 08:04 PM
Birdhunter1
03-24-2017 03:47 PM
johnhammond
02-17-2017 05:42 AM
On1wheel01
1999 to 2016 Super Duty
11-13-2016 10:18 AM
Armytruckchuck
08-05-2016 11:26 AM
Quick Reply: 5 bolt auto hubs to manual conversion?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
