Adding water?
Old Aug 10, 2004 | 10:58 PM
ExcellentRed's Avatar
ExcellentRed
Adding water?
Hey guys,
I recently did some minor engine work on my 93 F-150 and drained the coolant. When I added more, dad told me to just put straight antifreeze into the system, and I didn't think anything of it. Then a friend of mine said that water needs to be mixed in with the antifreeze, and sure enough, the back of the antifreeze bottle says it should be a 50/50 mixture.
I realize this is a basic question, but should I drain some coolant and add water? Is it really crucial that water be mixed with the antifreeze? My truck rarely sits in traffic and never overheats. Thanks.
Old Aug 11, 2004 | 01:27 AM
fordflaresides's Avatar
fordflaresides
If it's straight antifreeze in there I would drain some and add some distilled water, a 50/50 mix will provide the best cooling.
Old Aug 11, 2004 | 11:48 AM
ExcellentRed
Okay, thanks. So its the water that actually does the cooling, and the antifreeze that keeps the coolant from freeze/boiling?
Old Aug 12, 2004 | 02:09 PM
fatherdoug's Avatar
fatherdoug
By adding straight antifreeze, you have effectively reduced the boiling temperature of the solution. A pure antifreeze solution has a freeze point of -10 deg F, while a 60/40 mix of antifreeze has a freeze point of about -50 deg F(don't remember the exact figure). Something else to consider is the concentration of corrosion inhibitor( too much of the corrosion inhibitor in a system can actually raise the pH of the solution, which causes instead of inhibits corrosion.)
tractormanbill
Feb 22, 2015 06:28 PM
Jolly Roger Joe
Nov 10, 2011 10:09 AM
midapo
Mar 6, 2011 10:39 PM
Ned Nimrod
Dec 10, 2006 01:16 AM
FEmtnmax
Jan 4, 2006 08:15 PM
