Antifreeze question
Old Oct 22, 2011 | 10:35 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Antifreeze question
I have a stock 226 which is running great but has only water in the cooling system. I want to put antifreeze in, and remember when I was younger, a 50/50 mix water/antifreeze was common.
First question: Do I want to use a 50/50 mix? Or, is it better with modern coolant to run 100% coolant?
The Shop Manual says my radiator is 18 quarts. I don't know how much water is in the block.
Second question: How much antifreeze do I put in the radiator (after draining it) to achieve the desired ratio of water to coolant?
If I'm just looking for a 50/50 mix in the radiator, that would be a little over 2 gallons of coolant.
Old Oct 22, 2011 | 10:48 AM
raytasch's Avatar
raytasch
Believe Nothing
It really depends on how low temperatures you can expect. In southern CA I doubt if you get much below freezing if at all and won't experience freezing unless you are going to a ski area Usually a 50/50 is a good mix for most locations and will prevent rust. Carefully read the labels on the containers as it is common practice to sell the pre 50/50 mix at about the same price as pure antifreeze. If you mix your own, use distilled water so as not add unwanted minerals to the system. No, you do not want to run pure antifreeze.
I would think two gals would do the job, that is what I run in my FE powered '73 and my Y block '56.
Old Oct 22, 2011 | 02:18 PM
Jolly Roger Joe
Thanks Raytasch.
We usually get a few nights below freezing each year, which is why I want to be ready with the antifreeze already in the system.
I haven't worked on car in so long, I didn't know if the 50/50 mix was still used.
Old Oct 23, 2011 | 03:33 PM
Longland's Avatar
Longland
Originally Posted by Jolly Roger Joe
Thanks Raytasch.
Yup, thats still the norm, around here at least. It also protects you from boiling over in the heat. What I do when I want to start from scratch is drain the Rad AND take out the block drain plugs. Measure all that you got out, if it's close to what the system is supposed to have great. I mix mine in a bucket to 50/50 THEN pour that in, that way EVEN if I don't get everything in that it should, at least it's close to a 50/50 mix. If what you get out is a little less than required then mix it up a little stronger then pour it in. DON'T FORGET to put drain plugs back in. And sometimes the holes where the plugs came from are plugged up, so check that to.
Old Nov 9, 2011 | 07:40 PM
Jolly Roger Joe
Well, I got around to draining the radiator last night (again) after I got home from work. Pacific Standard Time. Oh yeah, that means "In the dark".
I poured in one gallon of Prestone, and it filled the radiator. So I started the truck, waited for it to warm up, and the thermostat obviously works, as the coolant receded from the radiator. I poured in the second gallon. It took less than one gallon of water after that, so I'm assuming there's over a gallon in the engine that didn't drain from the radiator.
I let it run for several minutes with the same result. The water/coolant mix was getting hot, as vapors rose from the uncapped radiator.
I think I'm all set for our terrible SoCal winter now. It might freeze... well, it might. One more thing off the list.
Old Nov 9, 2011 | 11:14 PM
tinman52's Avatar
tinman52
Welder User
Hey Joe, FYI your block has a coolant drain (or plug) by the oil filler tube. You're right, not all the coolant will drain out thru the rad. I'm sure you got plenty in there now anyway...
Old Nov 10, 2011 | 07:52 AM
Jolly Roger Joe
Yeah, I call that a freeze plug. I have never taken one out, and I didn't want to now since I got the two gallons of coolant in there. I sorta figured that's how everyone gets a 50/50 mix.
Old Nov 10, 2011 | 08:22 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I think 50-50 will be fine for your area. Here in the north country I run enough to protect down to minus 35 which works out to be about 80% antifreeze and 20% water. Use distilled water to keep rust out...
Old Nov 10, 2011 | 09:19 AM
wilsel's Avatar
wilsel
Most auto parts stores carry a freezing/boiling point tester, for around $10. It's like a fancy turkey baster. You press on the rubber bulb to suck up coolant from the radiator, and a needle inside will tell you the freezing and boiling point of the mix. Glad I decided to test mine, because the freezing point was 24 degrees. That means it was mostly water. I honestly don't know how it didn't freeze before now, and crack the block. That's the only sure way to know you have the correct mix.
Old Nov 10, 2011 | 10:01 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The other reason to run 50-50 is that antifreeze is full of additives to prevent rust, neutralize acids, and lubricate the WP seals.
Wilsel, I had one of the type of tester you describe and found it to be wildly inaccurate. The counterman I trust at NAPA told me he had similar results and switched to the (cheaper) type with floating *****. You're on the safe side tho by adding more antifreeze.
Old Nov 10, 2011 | 10:09 AM
brain75's Avatar
brain75
The floating ***** one can be way off as well. My mom got a 2 pack of em for $2, identical 1 says tap water has protection down to freezing (ok I believe that), the other says 24 degrees... uh no way. Now that is just the 1st ball, after that the rest of the ***** line up correctly.
I did not know of the block drain plug, I simply parked it on a slope to get the block angled forward.
On mine recent flush and fill the 50/50 mix pegged out the 5 floaty ball style (-40 degrees) and the system took just under the 4 gallon of mix. Ran it around the block and retested and the last ball was half float / half sink (-20) so I left it there.. Obviously I didn't get all the clean flush water out of the system.
I think the QA process on stuff these days is just horrid - not your Japanese electronics, man that stuff is tight, everything mechanical made in china - gah!
(I'm still waiting on my Hong Kong PWM btw :P)
High_HP
May 18, 2018 01:12 PM
JonArmy
Sep 30, 2011 09:47 PM
wuttrd
Dec 9, 2009 01:37 PM
timferguson
1983 - 2012 Ranger & B-Series
Dec 11, 2006 08:34 AM
abelmoreno
Dec 15, 2005 02:28 AM
