Water Pump and Coolant
Old Mar 6, 2011 | 10:57 AM
midapo's Avatar
midapo
I am replacing my water pump and while Im at it some hoses. When I finish, I would like to make sure it does not leak before I add anti-freeze. So I thought of filling it with water for a pressure test, then draining and adding coolant.
Would there be any danger in this and for how long could I run it this way? No danger of a freeze here in Texas. Would tap water be ok for initial test or should I use distilled?
I was thinking of using motorcraft gold antifreeze, as I have read it has the proper sca. Any other suggestion on antifreeze would be appreciated.
Old Mar 6, 2011 | 11:16 AM
84-6.9L's Avatar
84-6.9L
After i did my head gaskets i ran water all summer. If they ended up leaking again i didnt want antifreeze in with my new bearings. Water is the more efficent at dissipating heat then a water/coolant mix. If you use distilled it can stay in there a long time but you may get some rust issues in a few months. But for testing tap water is ok.
Old Mar 6, 2011 | 12:02 PM
midapo's Avatar
midapo
Yes, I think the cooling will be fine. I was concerned about the cavitation issue. I think that I will use distilled for the test. That way when I do drain it, more of the water in the block will be distilled.
Old Mar 6, 2011 | 12:06 PM
84-6.9L's Avatar
84-6.9L
You should still be ok for a short time. scas can be added to water too i believe
Old Mar 6, 2011 | 12:43 PM
87crewdually's Avatar
87crewdually
Don't put anything in it and just pressure test it with a radiator pressure tester. Pump it up, go have coffee, come back if the pressure is the same your good.
If you don't have one you can borrow one from an auto parts store like Advance.
Old Mar 6, 2011 | 04:25 PM
midapo's Avatar
midapo
That's cool. Ive never seen one. I guess it has what pressure you need to pump to?
Old Mar 6, 2011 | 04:39 PM
ah1988's Avatar
ah1988
Harbor freight sells them for $80, might be worth investing in ,
Old Mar 6, 2011 | 06:45 PM
midapo's Avatar
midapo
I guess, if you do have a leak, then the only way to find it is filling it up?
Old Mar 6, 2011 | 06:55 PM
84-6.9L's Avatar
84-6.9L
You should be able to rent one from an auto parts store also
Old Mar 6, 2011 | 09:09 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Be sure to check the SCA levels once it's filled up just to make sure it actually does have the proper amount.
Old Mar 6, 2011 | 10:39 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
my suggestion;
low silicate (a must) traditional coolant (can be pre-mixed with SCA's.)
motorcraft or cummins/fleetgaurd SCA's to replenish with.
new motorcraft (brand specific is a must.International has one also,but imho;not for use in a pickup.it opens too early.poor fuel economy.back to facts; aftermarkets will not work properly period.) thermostat.
new 13 lb (a must) rated radiator cap.
new upper & lower radiator hoses.
4 gallons coolant/4 gallons distilled water (a must.)
test SCA levels every other oil change.add when required.flush every 2 years max,unless using a coolant filtration system.
tonyford
1983 - 2012 Ranger & B-Series
31
Nov 9, 2019 02:28 PM
Motsiball
15
Sep 23, 2016 05:16 PM
jreilly57
20
Jan 17, 2015 07:31 AM
pYr8
May 12, 2013 11:13 PM
b4hntn
1978 - 1996 Big Bronco
Jun 21, 2008 05:51 PM
