Antifreeze question
Old Feb 22, 2015 | 06:08 PM
tractormanbill's Avatar
tractormanbill
tractorman
Antifreeze question
I want to end up with a 50/50 mix in my radiator but when I first filled up the radiator I started with antifreeze and then added water.
My problem is I don't have any idea of what kind of mix I have.
Does anyone know what a 50/50 mix should check on the temp scale.
TractormanBill
Old Feb 22, 2015 | 06:20 PM
ALBUQ F-1's Avatar
ALBUQ F-1
All the auto parts places, Walmart, etc sell a little thing that's like a battery hygrometer, with little ***** or a needle that tells you what % you have by sucking a little into it. Not sure what you mean by "temp scale"?
Be sure to run it a while so it's mixed up before testing it.
tractormanbill
tractorman
Antifreeze
Thank I figured out the 50/50 mix as it should test around -34 to -37 degrees.
TractormanBill
Old Feb 22, 2015 | 06:24 PM
tractormanbill
tractorman
Antifreeze
Thanks,
Most I have used over the years calibrate to the temperature.
On the "easy to use ones" I didn't know it shows the percent of mixture along with the safe temperature.
Bill
Old Feb 22, 2015 | 06:28 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Might be on the side of the antifreeze jug? (-34) sounds right for 50-50.
High_HP
May 18, 2018 01:12 PM
Jolly Roger Joe
Nov 10, 2011 10:09 AM
fonzie
Dec 5, 2010 10:59 PM
wuttrd
Dec 9, 2009 01:37 PM
Birds 05 F-350
Sep 17, 2005 12:14 AM
