speed sensor question
Old Aug 10, 2004 | 10:05 PM
duback66's Avatar
duback66
I have a 1989 f150 with an 300-I6 and I the other day the truck died on me twice while I was comming to a stop. I read somewhere in the forums that the speed sensor on the transmission could cause this. Right now my speed sensor is unpluged because my speedometer cable is broken. Could this be the cause of the problem?
Old Aug 10, 2004 | 10:21 PM
MustangGT221's Avatar
MustangGT221
No, the speedometer in your vehicle has nothing to do with the engine running.
Old Aug 10, 2004 | 11:23 PM
duback66's Avatar
duback66
Thanks. Guess I have another problem then. (I thought that sounded too easy)
Old Aug 11, 2004 | 04:06 PM
EPNCSU2006's Avatar
EPNCSU2006
Actually, it might. Check the computer for codes - if it is a problem there will be a code for a missing speed sensor input.
Old Aug 11, 2004 | 10:00 PM
MustangGT221
On an 89? There's no sensor..its just a plastic gear, theres no signal...
My 95 doesn't pop a check engine code/light when it's disconnected.
Old Aug 12, 2004 | 11:56 AM
EPNCSU2006's Avatar
EPNCSU2006
I have a VSS input on my '87 computer, as well as the '90 mustang computer I'm currently running. There is a speed sensor on the output shaft of the transmission along with the speedo cable that runs cruise control and sends a signal to the computer. I don't think it would set a check engine light, but it would store a code. I am unfamiliar with the '95's, so I can't say how they are set up or if the computer uses any kind of input for vehicle speed.
Old Aug 12, 2004 | 04:10 PM
duback66's Avatar
duback66
It has a speed sensor connected at the place that the speedometer cable is connected. I know it runs the cruise control, but I don't know what else. How hard is it to check the computer codes?
Old Aug 12, 2004 | 07:51 PM
EPNCSU2006's Avatar
EPNCSU2006
It's pretty easy - go to http://fordfuelinjection.com and click on "Getting Codes"
Old Sep 5, 2004 | 12:17 PM
harmdogg1978's Avatar
harmdogg1978
When I go to a parts store and request a speed sensor for my truck (1989 F-150 4.9 4spd) the speed sensor they bring out is different form the one that is in it? the numbers on my old one match to a 1991 F-150.... why is this
Old Sep 6, 2004 | 07:36 PM
EPNCSU2006's Avatar
EPNCSU2006
There are two different speed sensors on your truck. There is one mounted on the top of the rear axle, and another on the output shaft of the transmission.
slider6075
Oct 23, 2012 09:27 PM
bbor62
1983 - 2012 Ranger & B-Series
Jun 21, 2004 11:22 PM
acastignetti
Mar 8, 2004 06:11 AM
Randyvan
Aug 26, 2003 10:32 AM
