Speed sensors
Old Aug 24, 2003 | 08:02 AM
Randyvan's Avatar
Randyvan
Speed sensors
I have a 91 Ford chassis under my motorhome the speed sensor went bad and I had it replaced. 250 miles later it went bad again this time the trans will shift through all the gears except into OD. It has a 460 engine and a E40D trans. Could a binding speedo cable cause this problem, I hear a clicking at the speedometer that is the reason I'm wondering if the cable might be binding a little.
Old Aug 24, 2003 | 08:22 PM
steve83's Avatar
steve83
Speed sensors
More likely the speedo drive gears are stripped, and the VSS just isn't spinning.
Old Aug 26, 2003 | 10:32 AM
Randyvan's Avatar
Randyvan
Speed sensors
Steve83 thanks for the reply. When I pulled the speed sensor the
plastic gear on the end has been chewed up some what. The gear that you are talking about is the one inside the tranny if I'm reading you right? Or is it the one in the speedo it self? Do you know if I can get just the gears or do I have to get a whole new sensor? Thanks again.
randy foster
1983 - 2012 Ranger & B-Series
Dec 11, 2013 10:06 AM
graymule
Jul 3, 2010 04:32 PM
64fordf100292
Sep 16, 2007 07:20 AM
99f350sd
Jan 23, 2007 07:49 AM
CaseyJones
1978 - 1996 Big Bronco
13
Jun 3, 2005 10:25 AM
