03 Expedition speed sensor question
Old Mar 7, 2004 | 08:13 PM
acastignetti's Avatar
acastignetti
Can anyone tell me where the speed sensor is located on an 03 expedition? My speedometer is not working and I want to check the connection. Also is there a blown fuse circuit that cause this?
Thanks,
Old Mar 7, 2004 | 08:57 PM
daveplot's Avatar
daveplot
Condition:
The speedometer/odometer is inoperative
Possible Sources
-Circuitry
-Powertrain control module (PCM)
-Instrument cluster
Looking through the Service Manual and Powertrain Control/Emissions Diagnosis Manual you really can't do much without some expensive test tools. I would suggest going to your dealer.
Old Mar 7, 2004 | 09:43 PM
Monsta's Avatar
Monsta
Sit. Stay.
On other Ford trucks the speed sensor is located on top of the rear differential. It "reads" the road speed by counting the revolutions of the ring gear.
I cannot imagine that the Expy would be different from other Ford trucks.
Still...if it's under warranty...
Old Mar 8, 2004 | 06:11 AM
acastignetti
Thanks guys,
the speedo stopped working after hitting a rather large puddle.
I thought I would check the speed sensor/pickup connections if I could find out wher they are located.
xtamer
Dec 19, 2017 08:46 PM
Wesley Redondo
Modular V8 (4.6L, 5.4L)
Jan 26, 2017 01:38 PM
bronco6767
Nov 12, 2016 09:46 PM
kuszmaul
Feb 13, 2016 06:55 PM
knightrider955
Jan 24, 2016 09:07 AM
