4.0L Temperature Gauge Fluctuation / Thumping in Cooling System
Old Aug 8, 2004 | 01:40 AM
Rockledge's Avatar
Rockledge
I've seen a few posts recently regarding temperature gauge fluctuation and/or a "thumping" in the cooling system of the 4.0L OHV engine. I figured I would post a few TSBs that I have run across that are applicable to this issue:
ARTICLE NO. 97-18-9
• COOLING SYSTEM—TEMPERATURE GAUGE FLUCTUATION—VEHICLES WITH 4.0L ENGINE
• NOISE—“THUMPING” HEARD FROM WATER PUMP AREA—VEHICLES WITH 4.0L ENGINE
FORD: 1994-97 AEROSTAR, EXPLORER, RANGER
ISSUE
A “thumping” noise or temperature gauge fluctuation may occur on some vehicles. This may be caused by the water pump delivering an uneven flow throughout the engine.
ACTION
Replace water pump and gasket with revised Water Pump (F7PZ-8501-AA) and Gasket (FOTZ-8507-A).
Refer to the appropriate year Aerostar/Ranger/Explorer Service Manual, Section 03-03, for water pump replacement procedure.
PART NUMBER / PART NAME
FOTZ-8507-A / Water Pump Gasket
F7PZ-8501-AA / Water Pump
ARTICLE NO. 99-23-8
• GAUGE—TEMPERATURE GAUGE FLUCTUATION AND/OR “KNOCKING/THUMPING” NOISE FROM COOLING SYSTEM—4.0L OHV ENGINE
• COOLING SYSTEM—PULSATING COOLANT FLOW —NOISE—“ KNOCKING/THUMPING”— AUDIBLE IN PASSENGER COMPARTMENT—4.0LOHV ENGINE
FORD: 1995-2000 EXPLORER, RANGER
This TSB article is being republished in its entirety to include 2000 model year vehicles and to provide Service Part(s) and Labor Time information.
ISSUE
A temperature gauge fluctuation and/or a“knocking/thumping” noise may be audible in the passenger compartment on some vehicles. This noise is most pronounced with the engine at normal operating temperature. The noise is caused by steam formation in the cooling system. The noise is then transmitted through the heater hoses and heater core.
ACTION
Install a Coolant By-Pass Kit. This increases coolant flow which reduces steam formation. Refer to the following Diagnostic and Service Procedure for details.
DIAGNOSTIC AND SERVICE PROCEDURE
1. Check for excessive exhaust system restrictions. A restricted exhaust could elevate cooling system temperatures.
2. If dash-mounted cooling temperature gauge fluctuates, check that gauge and sending unit are functioning properly.
3. Check for restrictions or kinks in the radiator or heater hoses.
4. Pressure check cooling system for leaks.
5. Confirm proper Engine Coolant Temperature (ECT) sensor signal to EEC-V processor.
6. Check for correct 50/50 coolant mix. Verify that freezing point is -37*C (±-15*C) or -35*F (±5*F).
7. If concern still exists, install service Coolant by-Pass Kit and verify that concern has been resolved. Refer to the Application Chart in this article.
F8PZ-8522-AA / Coolant By-Pass Kit (‘95-‘96 Ranger)
F8PZ-8522-CA / Coolant By-Pass Kit (‘97+ Ranger)
Old Aug 8, 2004 | 03:59 PM
Dealford's Avatar
Dealford
Pretty much qualifies to become a new entry in the Tech.Info. sticky.
AL.
Old Aug 8, 2004 | 07:27 PM
Ken00's Avatar
Ken00
Will be in the next revision.
Old Aug 9, 2004 | 07:55 AM
pawpaw's Avatar
pawpaw
Had a similar problem with my 99 4.0L temp guage fluctuating, but no noise from the engine, as outlined in the TSB.
My fuel mileage had dropped off suddenly without a change in fuel vendors or driving habits.
The only thing I had noticed was a slightly lower than "normal" position in the coolant "idiot" temp guage. So I began to pay closer attention to it & caught it periodically, fluctuating up & down about 1/8 scale.
Replaced the OEM thermostat, about 37K miles on it, problems solved. Guage now stable, fuel mileage back to normal. Sticking thermostat I suppose.
Just some more input for consideration.
Old Aug 13, 2004 | 09:47 AM
McMurry's Avatar
McMurry
I had a similar "thumping" in my '92 Ranger with the 3.0 and 5spd. Local Ford dealer could never find the problem, but speculated steam in a water hose was the problem. Glad to know that I was not imagining it.
Old May 26, 2010 | 06:32 PM
abikerider's Avatar
abikerider
Had a similar problem with a 1995 4.0l Explorer and it turned out to be a bad radiator cap.
Old Mar 17, 2011 | 09:17 PM
fastcatboat's Avatar
fastcatboat
i am having this problem with a explore i replace the cap that stoped the leak stiill a thumping removed the therstat and all ok put in s new one bleed the air out i think and sitting still all ok took a road test the sounds came back upper water hose sucked shut and got to hot. i am stumped so now a water pump? its not leaking. a raditor?
Old Mar 17, 2011 | 11:30 PM
michigan66's Avatar
michigan66
Hi, "fastcatboat." What year is your Ranger? Would the above information - especially Rockledge's post about the Coolant By-Pass Kit may be the solution to your problem.
In the future, I would suggest that you begin a new thread when you have an issue you want help on. Many folks will never find your question since it is buried at the tail end of a number of posts. Just a helpful note to someone fairly new to FTE.
Old Nov 3, 2012 | 09:09 PM
acmccray's Avatar
acmccray
95 ford ranger
hi folks, i have a problem with my ford ranger when i turn it off i have a bumping noise in my water lines it continues for some time after wards and my hoses collapse as a result what can you tell me if any body has happened come up on a solution for this thanks in advance.
Old Nov 3, 2012 | 09:56 PM
pawpaw's Avatar
pawpaw
Welcome to FTE.
Have your radiator cap checked & the cooling system checked to see if its holding proper pressure.
What kind of condition is the coolant in????
Are you having an over heating problem when the engine is running????
Old Nov 4, 2012 | 07:25 PM
Phinxter's Avatar
Phinxter
Where was all this info when I had this problem???? My thump problem was caused by air entering the system during cool down from one of those POS flush tees. If you got one of those remove that hose and replace it. You can always use the old hose when you actually flush the system.
Old Mar 12, 2016 | 03:57 AM
abikerider's Avatar
abikerider
Finally Fixed for good
OK, after dealing with this off and on for years I noticed that it doesn't happen when on max air conditioning or if the heater selector is off. Both these settings cause the vacuum-operated heater bypass valve to bypass the heater core. It seems that there is not enough flow through the heater core and this is causing a hot spot in the engine and creating steam pockets.
My solution was to create a permanent bypass on the heater core using reducer tees on the heater hoses with some 3/8" hose used for the bypass. After I installed it the symptoms went away and stayed away and I still get plenty of heat from my heater. I hope this helps if anyone comes back to this thread.
Old Mar 12, 2016 | 06:18 AM
pawpaw's Avatar
pawpaw
Sounds like you reengineered the second TSB 99-23-8 that Rockledge put up in post 1.
Good to hear it works & your woes have taken a hike.
Old Mar 12, 2016 | 09:52 AM
Rockledge's Avatar
Rockledge
Good feedback, thanks.
davidstjohn1
87
Jun 30, 2022 07:54 PM
Teamtiger21
Mar 22, 2018 10:03 AM
86ford1
Mar 1, 2018 12:07 AM
gangstakr
13
Nov 5, 2017 07:31 AM
lauraj
Oct 13, 2017 04:24 PM
