302 shaved heads
Old Aug 5, 2004 | 06:52 PM
dmc919's Avatar
dmc919
302 shaved heads
i recently got my heads shave on my 302 and was wondering if the head are shaved will it put the valva train out of alignment, like will my push rods be to long?
Old Aug 5, 2004 | 08:58 PM
ga302p's Avatar
ga302p
more than likely, you will have to use shorter pushrods or shims.
Old Aug 5, 2004 | 10:10 PM
rainbowATF's Avatar
rainbowATF
Last week I got my 302 heads back from machine shop. My heads were shaved or milled slightly. I asked the machine shop and they said they removed minor amount to true up surface and I should use the stock length pushrod. So ask your machinist what they recommend.
Old Aug 6, 2004 | 05:05 AM
RTM's Avatar
RTM
What year heads do you have and how much was shaved? If to much is shaved then you may have a fitting problem with your intake. Non adjustable rocker heads could need shims if to much has been milled off.
greentruck72
May 4, 2015 04:02 PM
Old_Crow
Oct 31, 2012 11:17 AM
RC Dan
Apr 9, 2007 06:18 AM
JBradley500
Jan 28, 2007 10:58 AM
FordCardinal
Aug 15, 2004 03:31 PM
