AC in 78 F250
If you are adding this to your non A/C truck then you will need more than just a compressor and bracket (probably aware of that), but I would look for a rusted out 73-79 F series and get the complete setup.
The old YORK compressor's are hard to get part's for as well. Might want to look into upgrading to a newer R134 type of compressor.
I am planning the same thing. Just picked up a compressor and condensor coils with the dryer attached from a fellow FTE member here in Austin. Just need to get the ducts, controls, and vents for the interior (probably a new dash bezel as well). I will also need to find the big fan box for the firewall and some new coolant lines.
Anyone that has actually done this successfully have any advice or warnings? Problems to avoid? Thanks!
Originally Posted by dynamic
Any one happen to know what newer style compressors will fit in the place of the big bulky orginal york unit?
Marty
I got it out of an early 70's lincoln. I had the hoses mades to fit, as they didn't work with the dealer installed AC. The only pictures I have is without the compressor installed. But if you look at my Gallery, you can kind of see the PS mount and the two holes where the compressor mounts.
I only used it out of convenience. This setup uses the saginaw type pump instead. You may notice that the pump is tipped a bit, that is how much I had to bring the mount up to miss the steering gear.
Ryan.
Ryan.
