Sponsored by: Real Truck
Reprogramming keyless touch pad
Old Jul 28, 2004 | 10:21 AM
daimon1054's Avatar
daimon1054
I bought an Excursion and it has the touch pad to unlock the doors. The seller does not know the code so is there a way that I can reprogram it? If so how? I do not know if it was dealer installed or factory, does it make a difference?
Thanks
Old Jul 28, 2004 | 10:59 AM
wlihntr's Avatar
wlihntr
i think you have to have the old code to program in a new one. i had that keyless entry on my SHO, if i remember right the code was somewhere on the car , like on one of the door jams, or in the trunk. i think it said in the manual where to find the code.
Old Jul 28, 2004 | 11:07 AM
daimon1054's Avatar
daimon1054
When I sold ford's way back they were in the trunk on the strut and under the hood but the old code is not to be found on this truck so I figured there had to be some way????
Old Jul 28, 2004 | 11:09 AM
FortyFords's Avatar
FortyFords
The code is on a tag on the PATS system module .
I think it is behind the plastic panels in the rear quarter panels not sure which side .
You might want to ask in the excursion forum .
"on edit Damion its on the vehicle security module located behind the radio and heater controls. also the selling dealer can use a factory scan tool to retrieve the code for you.
Rich
Old Jul 28, 2004 | 09:56 PM
daimon1054's Avatar
daimon1054
Well fortyfords I looked behind the radio and no luck. The Ford customer hotline said it was on the Keyless module but they did not know where that was. I called 2 dealers and both said it was no where on the truck but they would be glad to charge me 80 bucks + tax to pull it out of the computer, that was when I called Ford. I will do without it before I pay one of the crooks at the dealership.
I am going to call some friends and see if they know where the keyless module is.
Thanks for the help
Old Jul 28, 2004 | 10:06 PM
FortyFords's Avatar
FortyFords
Daimon ,What year x is it ? This info came from my 02 factory shop manuals!
Is it possible its not a factory keyless?
Rich
Old Jul 28, 2004 | 10:15 PM
daimon1054's Avatar
daimon1054
it is an 01 I was azz deep under the dash with the radio and the fues cover and the great bag hanger all out and nothing had a #. OK lots of #'s and I think I punched every one in lol.
Old Jul 29, 2004 | 04:54 AM
ecajberry's Avatar
ecajberry
Try looking between the dash and firewall, left of the brake pedel, crammed up in there should be a box looking unit with a label on it with numbers (5 numbers). Thats where it was on my Expedition.
If i remember correctly, once the code it entered and the doors unlock, press 1 then 2 then your new code set. Its been awhile but i think thats how its done.
Keep in mind that both codes will now open the truck, since the factory code cannot be erased. Hope this helps.
Old Jul 29, 2004 | 08:08 AM
daimon1054's Avatar
daimon1054
Thanks but it's not in the same place on the EX, I had the fricken dash apart and looked every where and nothing but busted knuckles.
fortyford I think the location you gave is right, there is a module there but it does not have the #'s on it.
Thanks again.
Old Jul 29, 2004 | 11:29 AM
FortyFords's Avatar
FortyFords
Daimon ,Did you unbolt it and flip it over ? don't diconnect it though !!!!!
according to the manual its on it someplace ,again unless the module had been changed . Also if someone had entered their own code , you will need to do as the above poster had said about .entering the code and following the reprogram sequence in the shop manuals.
Rich
Old Jul 29, 2004 | 07:34 PM
daimon1054's Avatar
daimon1054
Heck I can hardley touch the thing lol. I called a friend who used to work at a ford shop tomorow he is going to sneak me into the shop and a friend of his is going to do it for free! Thanks for the info!!!!
mickwalker
2004 - 2008 F150
May 31, 2009 02:47 AM
rnolloth
Mar 8, 2008 07:25 PM
RAGaz
Apr 25, 2007 10:00 AM
boilerperson
Apr 6, 2006 10:42 AM
Crumm
24
Feb 12, 2005 01:36 PM
