Help! How to reprogram key pad
Old May 30, 2009 | 07:04 PM
mickwalker's Avatar
mickwalker
I have a 2004 f-150 FX4. The person I got the truck from does not have the number for the door key pad. Is there any way to reprogram it.
Thanks, Mick
Old May 31, 2009 | 12:08 AM
SMok's Avatar
SMok
You can add additional numbers, but you cannot erase the original code. The problem is you need the original key pad number to program additional key pad numbers. You have two options on getting the original key pad number. You can go to the dealership and get them to hook it up to there computer, but this will cost you some green. The cheaper way is to simply find the security module. The security module has the entry code on the label. If you have a 4 door, the module is behind the rear seat on passanger side. If its a two door, i think it is over behind the glove box somewhere, but i'm not sure. I always just use the scan tool. Hope this helps
Old May 31, 2009 | 02:47 AM
FTE Trigger's Avatar
FTE Trigger
Here's a similar thread that had passed through here about a month or so ago. https://www.ford-trucks.com/forums/8...-question.html
lilmick21602
1997 - 2003 F150
Apr 13, 2011 11:58 PM
fastmover
N. California Chapter
42
Aug 14, 2010 04:29 PM
RAGaz
Apr 25, 2007 10:00 AM
mick460
Wisconsin Chapter
Jun 3, 2004 09:07 AM
