Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
04 escape a/c problem
Old Jul 25, 2004 | 09:56 AM
fredpet's Avatar
fredpet
have a new 04 escape. a/c is acting strange. around town at low speed, all is fine. on highway or at high enging speeds, stops cooling. does not matter if on regular or max a/c. once off the highway, it slowly returns to normal. i've noticed that when the problem occurs, a/c compressor cycles on and off a lot and only stays on for a second or so. also, a/c compressor is LOUD when this is happening. can't normally hear it very much.
ideas??
Thanks,
adam
Old Jul 25, 2004 | 02:51 PM
Steina's Avatar
Steina
CO River Rat
Sounds like a vaccuum or low refrigerant charge problem, maybe both. Since it's new, let your dealer handle it.
Steve
Old Jul 25, 2004 | 05:53 PM
Mojave2k's Avatar
Mojave2k
I think that there is a engine speed control for the compressor that disingages it when the motor is revved for passing.. I may be defective and not allowing the compressor to stay ingaged at highway speeds...Just a thought... The dealer will sort it out, but don't wait untill the compressor's clutch gets burned up from excessive ingagements..
Old Jul 25, 2004 | 06:01 PM
Steina's Avatar
Steina
CO River Rat
Hey Mojave2k -
Where are you located? I'm in Victorville.
Steve
Old Aug 1, 2005 | 02:57 PM
hingabo's Avatar
hingabo
I have the same issue. Bought a vacuum hand pump and checked each component in the system under the dash and hood. Everything was fine EXCEPT the vacuum line that supplies vacuum to the interior. The default (with no vacuum) is to the defroster vents. At town speeds, the throttle position seems such that the engine developes enough vacuum to outrun the leaky hose. At highway speeds, the leak outruns the engines vacuum. Try this: when the air starts to switch from the dash panel vents and makes more noise, let off the gas pedal for about two (2) seconds. You should notice the air suddenly switches back to the dash vents. Happens evertime for me, confirming the leak. For air to come out the dash vents, three (3) vacuum pots need to be held with around 10-15 lbs. of vacuum (four(4) if in MAX AC. It's in the high 90's in OK so I haven't tried this on HEATER yet!! Anyway, the hose is about $24 from the dealer. Ordered mine a week ago and still waiting to see if they can get it. Being able to reach the thing to replace it when it comes in could be a whole different issue.
kountzecobra
Feb 22, 2016 08:38 AM
DeputyDawgAtl
Jul 2, 2015 10:21 PM
AggieOutlaw
May 19, 2015 02:26 PM
DesertZuki
Nov 9, 2014 10:45 AM
Samuelito
2009 - 2014 F150
Jul 27, 2011 05:28 AM
