starter relay
Old Jul 24, 2004 | 01:31 AM
mike390's Avatar
mike390
Question starter relay
should you still be able to start a truck by crossing out the starter relay if the fusible links are bad
Old Jul 24, 2004 | 02:55 AM
Torque1st's Avatar
Torque1st
Posting Legend
No, you can get the starter to turn but there will be no power to the ignition system.
Old Jul 24, 2004 | 03:00 AM
mike390's Avatar
mike390
i sure do appreciate it
Old Jul 24, 2004 | 03:19 AM
Torque1st's Avatar
Torque1st
Posting Legend
You are welcome
If you jump power to the second terminal marked "I" and jump power to the coil you may get it. Don't leave the power on the coil long. It kind of depends on how burnt up and shorted the wiring is.
Old Jul 24, 2004 | 04:22 AM
mike390's Avatar
mike390
Thanks Again
I'm Going To Try A Few Things Today I Bought Two Fusible Links Last Night At The Parts Store A 16ga & A 14ga There The Kind With The Open Eye Types That Mount On The Starter Relay If You Have Anymore Ideas I'm All Ears
Old Jul 24, 2004 | 10:21 AM
Torque1st's Avatar
Torque1st
Posting Legend
Find out why the links burned b4 you replace them. Check out your other wiring to make sure there is not a melted wire or burned insulation anywhere.
Old Jul 24, 2004 | 07:38 PM
mike390's Avatar
mike390
alright i can turn the ignition switch an nothing happens i replaced one of the fusible links and still nothing but i can cross out the starter relay and the starter will turn what else could it possibly be
Old Jul 24, 2004 | 08:56 PM
ranger429's Avatar
ranger429
Did you check to make sure you have power at the I terminal of the solenoid when the key is in the run position? Did you check all your fuses in the fuse panel?
Old Jul 24, 2004 | 10:41 PM
Torque1st's Avatar
Torque1st
Posting Legend
For detailed electrical system diagnosis I am moving this to the Electrical systems forum.
Old Jul 25, 2004 | 11:17 PM
Franklin2's Avatar
Franklin2
I am assuming this is a 70'ish truck? Do you have a testlight? If you can get one, or a meter, I would be curious if you have any power at all in the fuse box? Depending on what year it is, most Fords have large yellow wires feeding the ignition switch. These same wires should be out where you were fixing fusible links(out near the starter relay). If they are not yellow, you still should be able to match the colors out by the starter relay with a colored wire at the ignition switch. Do you have power on this wire at the ignition switch. This feeds the whole she-bang.
Old Jul 26, 2004 | 02:28 PM
mike390's Avatar
mike390
thanks to everybody i really love this site
Old Aug 2, 2004 | 07:39 PM
DUKEIN's Avatar
DUKEIN
electrical problems ....
1988 Ford Ranger 2.3L, discharges battery overnight. Replaced orig. battery with new, still discharges overnight. Installed newly charged battery, recorded voltage via DVM(some 12ish volts), start engine then rev motor, gets additional 2-3volts. Removed + terminal of the battery (engine still running), wiper ran crazy/uncontrollably. Installed back + term. it stopped.
Any ideas???
Old Aug 2, 2004 | 09:09 PM
ranger429's Avatar
ranger429
If it is discharging overnight you must have a short somewhere. With the motor off and the key in the off position hook a meter up inbetween your Pos cable and the Pos battery cable. If you are showing alot of voltage pull fuses to find what circuit is draining your battery. Bear in mind that the clock will draw a small amount of voltage.
disconnecting the Pos cable when the vehicle is running is not a good idea, you can throw a voltage spike into computer controlled pieces that cannot take it.
JordanL79
Jan 17, 2017 12:44 PM
Mab1957
Oct 21, 2015 01:25 PM
sunbelt57
Jun 16, 2015 09:25 AM
bobwhyte2002
May 6, 2012 10:30 PM
boeing777
Jan 29, 2009 07:50 AM
