Sponsored by: Auxito
Accessory position on ignition switch
Old Jul 23, 2004 | 09:38 PM
f4rhino's Avatar
f4rhino
I purchased a 1999 F-150 SC, and have yet been able to select this position. Is there some trick to it?
Old Jul 23, 2004 | 11:06 PM
LxMan1's Avatar
LxMan1
It should just turn back. There is either a problem with the tumbler assembly or the switch mechanism.
Old Jul 26, 2004 | 09:57 PM
coolk614724's Avatar
coolk614724
If someone has had the lockset out they may have moved the gears behind the switch if someone has done this then all you have to do is R&R the ingition lockset and behind it you will see a plastic retaning plate i think usually they are green remove that then there is a metal guide plate that you have to turn and then remove it then you will see two gears - the one where the shaft coming off the lockset goes into is the one you want to pull out and move it ( i cant remember if it goes to the 1st or 2nd tooth ) and then put everything back together and try it . I have seen especially on the ford 10 cut cylinders where the shaft on the back of the cylinder breaks off behind the metal guide plate and sticks in the gear so they pull the gear and then when they put it back in they put it in wrong this is uaually what happens.
Do your doors and ignition use the same key?
let me know
Old Jul 26, 2004 | 10:31 PM
f4rhino's Avatar
f4rhino
Yes ..my ignition key will also open the door..however, when I bought the truck the guy gave me a metal key, not a black key that has to be programmed..I am not sure what it is for...is it true that if you put in the ignition switch a non programmed key, it will mess up the computer??
Old Jul 26, 2004 | 10:39 PM
coolk614724
Well that should have a transponder system so you should have 2 big headed keys. Does the truck have remote start??
Old Jul 26, 2004 | 11:03 PM
f4rhino's Avatar
f4rhino
only came with one big head key...bought 2 more on ebay but have yet to take them to the Ford dealer toi get programs....no FORD STANDARD keyless entry...but truch has a Code Alarm system which works well
Old Jul 27, 2004 | 03:51 PM
coolk614724
I need to know if it has remote start?? not keyless entry but remote start?
Old Jul 27, 2004 | 05:23 PM
f4rhino's Avatar
f4rhino
no remote \start
Old Jul 27, 2004 | 05:48 PM
coolk614724
oh ok the reason i asked is because if you have remote start they installer will usually take one key and hide it up in the collum so that the computer see the transponser and will allow the vehicle to start does that make sense? did you buy the truck used? if so maybe it does have remote start you just dont know it or have a remote for it??? that would be the only way i know of about by passing the pats system.
as for no acc does the key turn back to the acc possition and there is jst no power or does it not turn back at all???
leonharu
Jan 4, 2016 10:27 AM
cliffs750
Electrical Systems/Wiring
Nov 14, 2015 08:31 PM
kevin-1966
Apr 22, 2015 07:33 PM
Grizzly93
Large Truck
Jan 19, 2015 02:25 AM
Jack DK
Jan 4, 2015 10:05 AM
