power windows
Old Apr 21, 2015 | 07:23 PM
kevin-1966's Avatar
kevin-1966
power windows
Hi everyone, I've been reading on this site for a couple of years , just joined. Lots if great info. here. I have a '86 f150 4x4 xlt lariat. super cab, long bed,351w c6. This seems like a dumb question but here it goes, My left. window goes up when the switch is in the up position. and down in the down position, the right window works the opposite(down with the switch in the up position and up with the switch in the down position) with both switches. Is this normal? thanks.
Old Apr 21, 2015 | 08:19 PM
Tedster9's Avatar
Tedster9
Welcome to FTE
They work, and you're complaining? haha. I'm wondering if the switch is just turned around.
Old Apr 21, 2015 | 08:53 PM
reamer's Avatar
reamer
motor plug backwards?
Old Apr 21, 2015 | 09:10 PM
ctubutis's Avatar
ctubutis
Ha!!!!!! LOL!!!!!
I'd rep you if I could.....
Old Apr 22, 2015 | 07:44 AM
Gary Lewis's Avatar
Gary Lewis
Originally Posted by ctubutis
Ha!!!!!! LOL!!!!!
Done! For Chris.
Seriously though, it is rare for both windows to still work. It is possible the switch is turned upside down. Or the leads to the motor are reversed. I'm guessing that it was repaired at some point, which explains why both work, but something was turned around.
Old Apr 22, 2015 | 08:19 AM
kevin-1966's Avatar
kevin-1966
I'm not complaining, I'm just curious if that is correct. If they didn't work I would put crank windows in. I preplaced both switches with ones from j.y. and checked the wiring, the switches only go in one way. I guess that should have been my answer. This is just a project in my garage for when time and money permit.
Old Apr 22, 2015 | 10:08 AM
1986F150six's Avatar
1986F150six
Welcome to the forum, kevin-1966!
Old Apr 22, 2015 | 12:49 PM
JimsRebel's Avatar
JimsRebel
When I bought my replacement window motor from Napa it did not have a connector on the two wires. It came with 2 butt splices and you had to cut off the connector on the bad motor and reuse it on the new motor.
My gut feeling is you need to swap the wires.
Jim
Old Apr 22, 2015 | 07:33 PM
biggamehunter222's Avatar
biggamehunter222
The windows on my 85' work the same way. People kept asking me about it so when I replaced the passenger motor I flipped the switch the other way when putting it back in the door. I like the controls "backwards" on my side though.
TexasGuy001
Jun 11, 2016 09:44 AM
fabrication
Electrical Systems/Wiring
Jun 27, 2010 09:19 AM
Mish
1997 - 2003 F150
Feb 24, 2010 07:36 PM
utahtom
Jun 30, 2008 07:36 PM
karljay
Aug 23, 2002 11:03 PM
