Positive Ground Strap:
Old Jan 4, 2016 | 08:59 AM
leonharu's Avatar
leonharu
Exactly what does the positive ground strap mount to on a 1952 F-1 with flathead 239?Carpenters has a strap listed that is only 9.5 inches log.That don't seem like that would be long enough to use????
Old Jan 4, 2016 | 10:20 AM
ALBUQ F-1's Avatar
ALBUQ F-1
That depends; do you want it Dearborn correct, or the right way? The stock setup was to ground to the firewall, from there to the block. Makes no sense, but the point on the firewall is about 9.5 inches from a stock old battery. Some older threads on it:
https://www.ford-trucks.com/forums/1...grounding.html
https://www.ford-trucks.com/forums/1...l#post15491901
My advice would be to measure how long a cable you need to get to a bolt on the bellhousing, and buy one at NAPA.
Old Jan 4, 2016 | 10:27 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
The Parts Catalog shows 14301 as the number for the straps but several different lengths for them. None of them are only 9.5" long.
Abinsur
Apr 28, 2021 09:57 AM
Superblue400
Oct 2, 2016 08:39 PM
F33lmywrath
Apr 15, 2016 07:54 AM
leonharu
Jan 13, 2016 03:12 PM
3twinridges
Oct 22, 2015 01:48 PM
