Taps for EGT guage...
Old Jul 23, 2004 | 10:43 AM
basstardo's Avatar
basstardo
Well, I'm finally getting around to relocating my EGT probe into the exhuast manifold. I'm pretty confident about doing this, but I wanna make sure I have the right tools ahead of time. I have an AutoMeter Ultra Lite series EGT guage and the probe that comes with it. Is this a 1/4 or 1/8 NPT tap? Also, looking at the website below:
http://www.vermontamerican.com/produ...646&GRP=170281
will those taps work?
Thanks,
Terry
Old Jul 23, 2004 | 10:54 AM
HeatStroked's Avatar
HeatStroked
Those are it.........My Autometer pyro probe took a 1/8" NPT tap.
Some mfrs. have 1/4" NPT though.
Old Jul 23, 2004 | 11:04 AM
basstardo's Avatar
basstardo
Cool deal. Since I have the AutoMeter I'll pull the 1/8th in tap.
Thanks,
Terry
Old Jul 23, 2004 | 01:29 PM
PickSty's Avatar
PickSty
I'm getting ready to do the same job. There's not much clearance in there to use a "T" handle on the tap plus I didn't want to spend the $9.00 to buy one that I'll probably never use again. My solution is to use a 3/8 inch drive 10mm 12 point socket (6 point won't work) to hold the tap and a 6" or possibly a 9" extention for the ratchet drive. This way I can do the twisting without running into things. It goes without saying that care must be taken to make sure the tap is going in straight.
Old Jul 23, 2004 | 03:42 PM
RedTaurus94's Avatar
RedTaurus94
Just remember that you don't thread a tapered pipe tap ALL the way through like you can a regular non-tapered tap. If you do, your threads will be a mile oversized. I think 3 rounds is it, but someone else may need to correct me on that.........
Old Jul 23, 2004 | 04:03 PM
PickSty's Avatar
PickSty
Thanks for that valuable piece of advice. I would have gone as far as I could go.
Old Jul 23, 2004 | 09:54 PM
RedTaurus94
I would trying "sneaking" up on it. Maybe do 2 or 3 rounds, then test fit....then if needed, I might go another round or two, then test fit again.........
Old Jul 23, 2004 | 10:51 PM
Kwikkordead's Avatar
Kwikkordead
YES!!! Test fit it.
Old Jul 26, 2004 | 08:48 AM
basstardo's Avatar
basstardo
Got it done over the weekend! Overall, wasn't particularly difficult, just time consuming. I started with a small pilot hole and worked up to 11/32 in 1/64" increments. I greased the bits as well to catch as much of the shavings as I could. Getting the tap in was the hardest part, but once I got it going, it went fairly smooth. The worst part is that I'm 6'10" and I don't fit under the truck real well, so it was a bit awkward moving around and staying patient. I did test fit mine as it went in, and it took me 3-4 times to get in far enough, but once I got it in it fit like a champ. My readings are much better now, and I feel a little more comfortable when I get on the throttle now that I'm getting an accurate reading. Thanks for your help guys!
Terry
HowieE
Nov 10, 2016 06:15 PM
coreyallan01
Nov 25, 2015 08:01 PM
maximusfd
Nov 21, 2012 11:13 PM
ocboat
Mar 27, 2011 10:19 AM
wildstang
Jun 19, 2009 10:34 PM
