tap size for isspro egt probe?
I think the info you have is correct as I recall. You try to position the tip of the probe in the middle of the area that you are installing in.
I'll go out to the shop and double check the drill size if it's correct I'll just let it slide.
You should have gotten some instructions along with the probe.
Rog
Rog
on
Thanks kawa and BlueMule. I have a friend that owns a machine shop and he has the correct R bit and tap. The thermocoupler box does say 1/8 steel tip so that must be right.
kawa when you said position the tip in the middle of the area, did you mean the area within the exhaust manifold?
thanks agian for the help.
