1978 - 1996 Big Bronco
AC vent problem
Old Aug 8, 2004 | 10:01 PM
ms_michelle's Avatar
ms_michelle
My Bronco is a 78 model
Michelle
Old Aug 10, 2004 | 06:44 PM
Black Ford XLT's Avatar
Black Ford XLT
Vacuum Hose
For the later model broncoes 92 on theres a white hose near your heater blower motor , seems this hose rots out faster than all ,get very brittle and if u do not touch it would be hard to miss seeing the cracks . Hope this helps Larry was that the hose (white) TR
Old Aug 15, 2004 | 03:37 PM
Tumblemark's Avatar
Tumblemark
Ouch! Hose pinched and me, too.
I ran out of time before a desert trip and had to let a dealer have a go at it. Basically, I was right. The stiff, black tube that comes from the intake vacuum port and passes through the firewall at the passenger's knees was faulty. The (clueless) service manager said it was pinched. "How could it become pinched suddenly?" I asked. He answered, "Oh yeah, it was leaky, too." A couple hundred bucks for four feet of tubing!
OTOH, the dealer also found another problem that could have left me stranded in 105 degree wasteland, so it wasn't a total loss. Just a big expense.
I think this type of problem (faulty air flap operation)should be easy to troubleshoot, especially with a vacuum gauge. It would be very easy with a diagram of the system after it jumps off the diagram on the sticker that's near the radiator. The hassle is taking the dash apart and working in very awkward areas.
Still, the flaps will revert to Defrost any time the vacuum drops enough, whether in Vent, A/C, or Heat mode. The A/C compressor keeps running, but the cooling effect drops off (like when you're pulling up a long grade in the desert). That's just the way the system was designed.
Old Sep 19, 2004 | 06:36 PM
Dutch123's Avatar
Dutch123
SoTumblemark- the black tubing from the vacuum intake was faulty and therefore the AC problem? Is the "faulty air flap operation" the same problem related to the black tubing?
So, your problem was resolve with replacment of the tubing, yes?
Dutch
Old Sep 19, 2004 | 06:49 PM
mustangman65_79's Avatar
mustangman65_79
Originally Posted by Broncobirdy
Mine was doing the same thing. The vacuum line just inside the firewall near the heater hoses on the passenger side was rotted. I cut the hole short and replaced the boot from Pep boys I think. Works great now. I think my lines were white in color. Good luck.
thats what was wrong with mine too
I used a peice of vaccum hose to fix it, but now it atting to rott farther up the line, now I have to cut the cover to get to the hose.
Old Sep 19, 2004 | 08:32 PM
JBronco's Avatar
JBronco
Did the dealer say that? It doesn't make any sense. I could understand if they made the compressor turn off to save power under load, but what's the difference if the air comes out of the dash vents or the defrost/floor?
Old Sep 19, 2004 | 10:13 PM
serverguru's Avatar
serverguru
Tumblemark has it right.
Must be an epidemic!
Mine started doing the same thing today.
Gonna try the stuff that is listed.
srag01
Aug 7, 2012 10:54 AM
clee2
Jul 23, 2008 07:04 AM
BigJake86
Jul 22, 2008 08:12 PM
ephraim95
Aug 19, 2007 08:22 PM
f100guy
Apr 22, 2007 10:33 PM
