problem with blowing through the wrong vents.
Old Apr 22, 2007 | 01:14 PM
f100guy's Avatar
f100guy
on my 85 when i turn the a/c or heater no matter what vent setting i have it on, the panel vents always blow. i don't have much pressure at the defrosters where i need it because it is blowing through the main vents too. is this a door problem. the vacuum diaphram is working up and down.
Old Apr 22, 2007 | 03:08 PM
Franklin2's Avatar
Franklin2
Look under the hood on the passenger side, and make sure your vacuum supply hose is connected and in good shape.
Old Apr 22, 2007 | 03:18 PM
f100guy's Avatar
f100guy
ok. it looks as though a cable could be connected to the vent selector because there is a mount for one but i can't find one. the diapram that is right behind the radio works when switched.
Old Apr 22, 2007 | 03:24 PM
f100guy's Avatar
f100guy
i checked, everything is good. the diaphram under theh hood by the blower motor works as well. is had to be a broken door or something. but is there a missing cable or what.
Franklin2's Avatar
Franklin2
There is a cable for the temp control, but this picture does not show a cable connected to the other lever.
http://www.autozone.com/images/cds/g...3d800a81fc.gif
Old Apr 22, 2007 | 03:27 PM
Franklin2's Avatar
Franklin2
Here's a picture of the one without A/C. It does use two cables.
http://www.autozone.com/images/cds/g...3d800a81fa.gif
Old Apr 22, 2007 | 10:33 PM
f100guy's Avatar
f100guy
i fixed it. i tore the dash apart today and found that the door that closes the defroster and main vents was broken off the hinges. i did some good rigging and used my soldering iron to melt 4 holes. 2 in the ducting and 2 in the door. i then used zip ties as hinges and it works great now.
Bronc1
1997 - 2003 F150
Nov 17, 2009 08:38 PM
mgdemarco
Oct 24, 2008 03:12 PM
clee2
Jul 23, 2008 07:04 AM
ephraim95
Aug 19, 2007 08:22 PM
