hydraulic clutch problem please help
Old Jul 20, 2004 | 10:06 PM
david nip's Avatar
david nip
Question hydraulic clutch problem please help
I have a 1984 f150 300 6 cly.clutch wasn't making any noise or acting up,but while driving petal only came half way back,and clutch won't engauge. tried bleeding at the slave cly. but still pedal only returns half way. clutch still wont engauge. i noticed that when pedal is pushed brake fluid comes out of cap where you pour the fluid in through small air hole. would this mean that clutch mastercly. is bad? thank you. ( is the allen screw on slave cly. where you bleed clutch? )
Old Jul 28, 2004 | 08:31 PM
Slammed150's Avatar
Slammed150
it sounds like either the clutch master is bad or the pressure plate is no good the allen screw is where it is bled out
hotrod91174
Nov 16, 2020 09:31 AM
uh60
Nov 10, 2013 07:45 AM
Wolf82636
Oct 21, 2010 03:12 PM
proia
Oct 19, 2007 10:37 PM
JR270
Jan 3, 2005 08:40 AM
