PC question???
Old Jul 20, 2004 | 02:00 PM
killerklown's Avatar
killerklown
PC question???
Everytime I open a second window in XP, it only opens minimized across 1/2 the screen... What do I have to do, to remedy this?
thanks
Old Jul 20, 2004 | 04:01 PM
rangerxlt02's Avatar
rangerxlt02
Couple different thoughts on this one:
After the second window is open:
Maximize it (icon in the upper right hand corner)
Close it right after doing this
Open a second window (does it open maximized?)
If opening from a shortcut on the desktop or elsewhere:
Right click on the icon (shortcut) | Properties
Change the Run option from Normal to Maximized
Old Jul 20, 2004 | 05:09 PM
droptop's Avatar
droptop
Minimize the first window and then manually resize the second window to fill the screen. Then hold down shift and close out the second window. Sometimes that will do the trick, but it probably won't last and eventually it will revert to the 1/2 size. I've heard it referred to as Windows' Window Amnesia.
Old Jul 20, 2004 | 08:01 PM
JamesF250's Avatar
JamesF250
When you close the screen, do not use the X. Instead go to the toolbar and go to File/Exit.
tjc transport
May 12, 2008 02:51 PM
wlihntr
Sep 2, 2007 08:48 AM
tjc transport
Mar 12, 2006 04:55 PM
Stroker_Deezel
Sep 27, 2005 10:37 PM
wezol5484
Aug 5, 2004 11:54 PM
