BAD vibration
Old Jul 19, 2004 | 12:18 PM
JoeDaddy15's Avatar
JoeDaddy15
BAD vibration
I'm looking at buying an 83 f-150 later today, and everything is beautiful on this truck, except it needs a tune up and it shakes like mad. I can see that the harmonic balancer is wobbling, but can it make the whole engione shake that bad? I'm just worried that I'll buy the truck and fix it, and still have a potentially bigger problem. I used to work for Autozone, and I know a lot about cars and motors, but have no real experience with V8's. BTW, I think it's a 302.
Old Jul 20, 2004 | 03:28 PM
Kemicalburns's Avatar
Kemicalburns
a new balancer should fix this along with a good tune up. depends on how much they are asking for the truck?
Old Jul 20, 2004 | 03:55 PM
JoeDaddy15's Avatar
JoeDaddy15
Well, I bought the truck for $1300. It drove home, and the body is straight with origonal paint and hubcaps. The motor runs like crap, and is knocking really loud. I'm not sure now if the harmonic balancer is what's wrong. The knocking sound gets louder and more frequent at high RPM's. I'll do all the tune up today, and see how it goes.
Old Jul 21, 2004 | 09:45 AM
mjl351w's Avatar
mjl351w
I hope that ain't a rod knocking ......but this dude i know had a chevy 4.3 with a bad (like gonna go thru the block ) rod knock and he used 3 quarts of that lucas he is still driving it today and that was 6 months ago
Old Jul 21, 2004 | 10:47 AM
Kemicalburns
That knocking would be piston slap due to bad rings. if it was a bearing they tend to only knock when there is no load on the motor.
Old Jul 23, 2004 | 11:06 AM
JoeDaddy15's Avatar
JoeDaddy15
I did the tune up two days ago, and it runs a LITTLE better. I also fixed most of the vacuum leaks, and it idles worse now. It dies when put into drive, unless it's cold and the choke is engaged. I didn't mention that there was no gas cap on the tank, and I think that might be contributing to the crappy running. The knock at idle sounds exactly like someone hitting the inside of the motor every revolution. If I rev the motor, it knocks up until I let off the gas, and then it returns at idle. I listened with a stethescope and it sounds loudest through the oil pan. Should I just buy a rebuilt short block, and rebuild? I was hoping to replace just rod bearings, but it sounds worse now. BTW, sorry about the long post.
Old Jul 23, 2004 | 11:07 AM
JoeDaddy15's Avatar
JoeDaddy15
BTW, is there a website or book or something to decode this carburetor? I can't find any adjustment screws anywhere!
Old Jul 23, 2004 | 12:39 PM
Kemicalburns
What kinda carb is it. I would look into a shortblock but talk to some machine shops first , maybe look into stroking that motor it will cost ruffly the same either way
Old Jul 23, 2004 | 01:52 PM
JoeDaddy15's Avatar
JoeDaddy15
I'm not looking for any performance upgrades. Just a dependable truck. I did remove the smog pump to get a better look at the timing marks, but still haven't found anything. This engine is not very user-friendly. And the carb is a stock two barrel. I can get the number if you want.
Old Jul 23, 2004 | 03:09 PM
Kemicalburns
i suggest you go on ebay and find a 4 barrel manifold and edelbrock carb. those 2 barrels are problem
Old Jul 23, 2004 | 04:45 PM
JoeDaddy15's Avatar
JoeDaddy15
The carb is second on the list, because I'm worried the motors gonna turn it's internals to mush. I'm looking at buying a rebuilt shortblock and using all the rest of my parts on it. I did find the timing marks on the balancer, but I don't know where the pointer is. There is a metal thing that looks like a loop and then another that comes to a point. If it's the point that I'm supposed to use, then my timing is at about 20 BTC and that's not good, especially on 87 octane and no gas cap. Ouch...
Old Jul 23, 2004 | 05:03 PM
Kemicalburns
yea, it should be around 10 btdc.
good luck
Old Jul 23, 2004 | 05:46 PM
JoeDaddy15's Avatar
JoeDaddy15
I turned it down to around 8 BTC, but now it idles worse, and the knock is still there. I think I'm gonna try some thicker oil, and some gas additive. How is the idle even adjusted on this carb? Is it in the linkage or what?
Old Jul 24, 2004 | 12:29 AM
grampztoyz351's Avatar
grampztoyz351
If it's a 7200VV junk it and get a real intake and carb.
manolo
Oct 2, 2012 02:27 PM
baxterl7333
2004 - 2008 F150
Jul 1, 2011 05:59 PM
Atwiss
May 17, 2011 12:51 PM
Skandocious
Apr 11, 2007 09:30 PM
oft
Dec 9, 2002 10:00 PM
