Light shaking at idle
Old Apr 11, 2007 | 08:02 PM
Skandocious's Avatar
Skandocious
I'm getting a very very slight but uniform shaking at a stop/idle. My RPMs are not surging or moving at all, but the truck gives a back and forth shake once every second or so. Its VERY slight and probably would go unnoticed by anyone who doesn't care about the truck as much as I do. Could this be motor mounts? Or a bad spark plug?
I'm also wondering if this has something to do with my high speed shake that I've been getting for the past couple months...
-Chris
Old Apr 11, 2007 | 08:30 PM
Redcat Diesel's Avatar
Redcat Diesel
No, it's not a motor mount problem.Worn or broken mounts will normally show up when pulling out or on deceleration.Usually a clunk or banging noise.The shake sounds like a weak plug or wire.The uniformity you describe is pointing me to 1 cylinder were a vacuum leak or other problem would make it idle erraticly.Hope this helps.
Old Apr 11, 2007 | 08:42 PM
Skandocious
Okay so you addressed two separate solutions there if I'm not mistaken. 1) Bad plug/wire, and 2) Vacuum leak near cylinder 1?? What does cylinder one have to do with vacuum leaks? Forgive my ignorance, I'm still learning.
-Chris
Old Apr 11, 2007 | 08:45 PM
OldRed4X4's Avatar
OldRed4X4
my truck does the same thing but only when i first start after i drive it than let it idle it doesnt untill i start it up again
Old Apr 11, 2007 | 08:49 PM
Hillbilly_Deluxe's Avatar
Hillbilly_Deluxe
mine was doing that. I changed the plugs, wires, etc. and it went away.
Old Apr 11, 2007 | 09:17 PM
Redcat Diesel
-Chris
Sorry Chris, my head sometimes overwhelms my **** poor (1 finger) typing skills. I was trying to say a vacuum leak will normally affect more than 1 cylinder and would be a lot more noticable.From your description it sounds like a weak plug or wire, which cylinder however I wouldn't even try to guess.
Clay
Old Apr 11, 2007 | 09:27 PM
Skandocious
Okay, well I was planning on doing a tune-up soon anyway (wires, plugs, dist cap and rotor). I guess I'll make it sooner than later, maybe this weekend if I can get around to it. Thanks guys.
-Chris
Old Apr 11, 2007 | 09:30 PM
Skandocious
Hey Hillbilly, was it giving you a high speed shake too? Real soft shake, almost unnoticeable? Or just at idle?? Thanks for the replies guys.
-Chris
myblkex
Jan 18, 2017 06:11 PM
myblkex
Modular V10 (6.8l)
Nov 19, 2013 07:17 PM
linus72
15
May 15, 2012 04:13 PM
haulingboat
13
Oct 20, 2008 11:53 AM
BlakeF150
Modular V8 (4.6L, 5.4L)
Jul 9, 2005 03:37 PM
