Black smoke and engine codes
Old Aug 4, 2004 | 10:19 AM
  #31
Wakeboarder141's Avatar
Wakeboarder141
I would assume so. Where is that located so I can check?
Old Aug 4, 2004 | 10:26 AM
  #32
gasman6674's Avatar
gasman6674
Right above the air pump. Passenger side. I beleve it is also controlled by a couple of soleniods on the drivers side. Try searching TAD or TAB I think. Sorry I can't be more sure I am at work and don't have access to my Haynes. Plus I have a "rusty" Memory
Old Aug 4, 2004 | 10:36 AM
  #33
Wakeboarder141
I have this stupid tube that connects to the Y-pipe that always falls off. Could that be causing that code? I will reconnect that and see if I get any change. I need to find some way to keep it from falling off.
Old Aug 4, 2004 | 10:39 AM
  #34
Kemicalburns's Avatar
Kemicalburns
fallow that tube up behind the motor there is a small canister that deals with emissions crap. it has a vacum line going into it as well. they tend to fail or melt down. check that area. but its hard to see with out the upper intake off
Old Aug 4, 2004 | 11:28 AM
  #35
Wakeboarder141
So, it wouldn't be throwing that code for as simple a reason as that metal pipe not being connected to the Y pipe?
ingram
Oct 6, 2017 10:05 PM
TrueBlue02
Nov 16, 2015 05:07 PM
kylek95
Aug 22, 2014 11:50 PM
Evan_P
43
Aug 8, 2014 12:10 PM
BluegrassPicker
Jul 20, 2011 06:39 PM
