i have a 1993 f250 7.3 non turbo. my wife took it to the store and when she came back the truck was smoking bad from under the hood so, i opened the hood and deisel was slug everywhere. i had her start it while i tried to find where it was coming from and it was coming out of what looked like the fuel pump. it was coming out in spurts. it looks like a plug fell out becouse the hole it was coming out of was a perfect circle. the truck still runs while it does this.
Any help would be great. should i replace it or is there a plug
are you sure its coming from the pump, if its is you need to replace it, there is a relive valve in the pump when it goes bad, make sure the fuel line hoses is on it tight& make sure the clamps are tight down to.
