Glow plugs won't come on
Does your glow plug light not come on? Is that what you mean?
It is most likely your GPs as the others have said. It might be the controller. Easy to check the GPs. Tricky to remove sometimes. There are some great posts on this. Good detail. Do a search, it will be well worth the minimal effort.
As already said only use motorcraft/beru zd-9 GPs. $9.99 each at autozone. others don't last, swell and burst etc. and make fubar out of your motor. Autolite are reportedly the worst.
i had major gp problems, spent about 1500 dolars trying to get it fixed, to the dealer 3 different times and two other private repair guys, nothing worked until i read on of the post about putting a manual button/toggle switch on the glow plug control relay. I have not had a problem since, the best thing i have done.
one of the post around here has a diagram on how to do it. It took all of about one hour to do/ very easy and well worth it
Mtew
12-24-2012 05:17 PM
lindar2177
10-20-2008 07:40 PM
fast freddie
11-09-2004 07:38 PM
