deisel everywhere
Old Jul 14, 2004 | 06:45 PM
jeter's Avatar
jeter
deisel everywhere
i have a 1993 f250 7.3 non turbo. my wife took it to the store and when she came back the truck was smoking bad from under the hood so, i opened the hood and deisel was slug everywhere. i had her start it while i tried to find where it was coming from and it was coming out of what looked like the fuel pump. it was coming out in spurts. it looks like a plug fell out becouse the hole it was coming out of was a perfect circle. the truck still runs while it does this.
Any help would be great. should i replace it or is there a plug
Old Jul 14, 2004 | 08:46 PM
Manitoulin's Avatar
Manitoulin
Where abouts on the pump was it leaking?
Old Jul 14, 2004 | 09:49 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Are you talking the injection pump on top or the lift pump on the lower right front?
How big is the stream/ hole?
Old Jul 15, 2004 | 12:46 AM
Manitoulin's Avatar
Manitoulin
it would have to be the injection pump to have a big stream.
Old Jul 15, 2004 | 07:53 AM
fellro86's Avatar
fellro86
if it's the lift pump, you will have to replace it. If it's the injection pump, top center of the engine, you'll be needing to get that hole plugged.
Old Jul 15, 2004 | 11:12 AM
jeter's Avatar
jeter
it would have to be the lift pump because it is on the right front of the engine. it a pretty good sqirt of feul
Old Jul 15, 2004 | 11:16 AM
jeter's Avatar
jeter
it is on the lower right side of the engine. it is shooting fuel right into the fan. that is why it is getting sprayed EVERYWHERE!
Old Jul 15, 2004 | 06:49 PM
FORD DIESEL's Avatar
FORD DIESEL
are you sure its coming from the pump, if its is you need to replace it, there is a relive valve in the pump when it goes bad, make sure the fuel line hoses is on it tight& make sure the clamps are tight down to.
Old Jul 15, 2004 | 09:36 PM
bphillman's Avatar
bphillman
just did that pump on mine last week. easy stuff. $25 new from carquest
amer28
Apr 2, 2011 07:14 PM
jearll
Feb 8, 2011 12:24 PM
zacm7
25
May 28, 2010 02:42 PM
Big George 150
Apr 14, 2005 07:46 AM
llp
Mar 31, 2005 01:04 AM
