91 Explorer Power Steering Pump Leak
Old 06-20-2002, 03:56 PM
chili97's Avatar
chili97
chili97 is offline
Hi
My 91 explorer has developed a signficant leak from the power steering pump reservoir. I poked around last night and it looks like the leak is coming from the outlet that you can easily see. It looks like it has a nut holding a tube into the reservoir. Has anybody ever experienced this, what part did you need to replace it, and how difficult a job was it to do?
Thanks
Marco
Old 06-21-2002, 06:19 AM
adbradley's Avatar
adbradley
adbradley is offline
I assume you are talking about the hose that runs into the side of the power steering pump. Mine leaks too, I jut keep filling it up. Mine is pretty rusted and I have had bad luck in the past with breaking the lines off inside the pump and then I have to replace the pump. I bet you can grab the line and move it around a little, which is why it leaks. The solution is to replace the line, but like I said, you'll be lucky if you're not replacing the pump too...
Old 06-23-2002, 08:16 PM
mike18's Avatar
mike18
mike18 is offline
hey guys i'm new to this forum
but i've got a 91 ford explorer. I've had 2 problems w/the power steering unit leeking. the first time it leaked from the hose. I basically disconnected one end of the hose and cut off about an inche of the hose(including the section with the leak) then reatached it.
the second time the leak was from the lower pitman arm. I'm not sure if thats what your talking about but after i went out and bought a pitman arm puller and the seal the replace the old seal,,,,i tried putting in a fluid that i bought from wal-mart. it was in a beige bottle. about 3 bucks and it said it was the strongest or heaviest (whatever) power steering leek stopper. i only used about 1/3 the bottle and the leak stopped in about 1 day.
The leak was really bad b4 i added the fluid.
I hope this short novel helps you out a little.
mike
Old 06-24-2002, 11:50 AM
chili97's Avatar
chili97
chili97 is offline
Mike
Some good poop! I'll hit up wal-mart this afternoon to go looking for the fluid you were talking about.
Thanks
Marco
Old 06-29-2002, 12:11 AM
burk97's Avatar
burk97
burk97 is offline
to the leak on the reserve on the 4.0L disconnect your line, inspect it should have a teflon washer on the end , I had the same problem because some idot used a o-ring.
Old 06-29-2002, 12:50 AM
blu93gt's Avatar
blu93gt
blu93gt is offline
pdqtimetrialer
2004 - 2008 F150
08-07-2016 09:28 PM
Punisher29073
01-29-2016 02:33 PM
PNWsail
Large Truck
01-18-2016 02:30 PM
76ClydeF100
06-23-2014 10:23 PM
TonyTug
02-16-2012 11:36 PM
Quick Reply: 91 Explorer Power Steering Pump Leak
