1997 F800 Hydro pump? Bill?
My 1997 F800 has a GVW of 24,500 with the 5.9 12valve Cummins, an Eaton Fuller 5205a manual transmission in it. The engine has two hydraulic pumps, one is gear driven off the engine with hoses running to the power steering gear.
The second one is on top, looks like a power steering pump with remote reservoir, and is belt driven. The hoses connect to the brake system, however it uses power steering fluid (indicated by a label on the reservoir) This pump is leaking fluid around the shaft seal, but otherwise works fine. So far, I have not been able to locate a seal kit for it. My factory shop manual diagrams are consistent with what I have on my engine.
When I look at the usual parts sources, O'Reilly's, Autozone, RockAuto etc, a power steering pump references the gear driven unit, and a brake booster pump goes to the Master Cylinder electric pump. Any advice?
(I will try to upload a pic from my phone in a moment)
They give FTE members parts discounts, but only if ordered online.
On some, the P/S pump used TYPE F ATF (it's red).
FTE Ford Dealer Parts Dept sponsor: Horizon Ford Truck Center: I've been there, it's just north of the Sea-Tac airport on International Blvd in Tukwila / horizonpartsguy.com
notucker
07-28-2021 03:07 AM
gustang818
03-01-2007 04:06 PM
92 Red F150
05-08-2003 08:01 PM
