Sheared Intake Bolt/Distributor Removal
Old Jul 12, 2004 | 11:09 AM
TMF's Avatar
TMF
Just tracked down the coolant leak on my '94 F-350 w/351... I thought it had been the temperature sender switch on the left front of the intake. Unfortunately, the intake bolt next to it (#6 in the tightening sequence - the one that runs through the water jacket) is snapped off and apparently has been for some time...
There's about 2 inches I can take out, the rest is in the block. My plan is to pull the intake and use the appropriate tool (reverse drill bit/EZ-out) to remove the snapped piece.
I believe I can pull the intake without having to pull the distributor as it looks as though there is enough room, especially once the upper manifold is removed.
Can someone confirm/deny for me? Thanks in advance!
Old Jul 12, 2004 | 11:36 AM
KwikFord's Avatar
KwikFord
You can try removing the intake without taking the distributor but I've been working on cars and trucks for over 20 years and I find it nearly impossible.
if someone have tips then please posted it here.
FilmCarp
16
Dec 28, 2014 08:54 PM
warren561
Sep 9, 2014 08:42 PM
eradicator006
May 7, 2012 02:13 PM
61 uni
Dec 2, 2007 08:24 AM
Monty06
Bronco II
Nov 13, 2004 06:25 PM
