Bronco II Ford Bronco II
Tfi Module
Old Nov 13, 2004 | 08:21 AM
Monty06's Avatar
Monty06
Tfi Module
my tfi module snapped in 2, i have been trying to start my truck since friday nada about 10pm i check the the module and i got 2 pieces out it snapped
thankfully i have another tfi, but here is my problem the distributor is loose to the bolt that holds it in place fell off and it's not aligned i can't remember how to set it help help help
Old Nov 13, 2004 | 06:25 PM
Ken00's Avatar
Ken00
If you mean the hold-down bolt came loose and the distributor moved you need to pull the spout and connect a timing light then set the timing to 10-12'.
BRONC-OH
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 28, 2019 11:14 AM
rockittsled
May 22, 2014 08:03 AM
WarWagon
Electrical Systems/Wiring
Feb 19, 2007 03:45 PM
danlee
May 19, 2005 07:20 AM
frachubb
Bronco II
Oct 21, 2003 08:22 PM
