GT Troubleshooting
Old Jul 10, 2004 | 01:03 PM
amalivuk's Avatar
amalivuk
GT Troubleshooting
Good Afternoon,
I'm totally new to this forum idea so please bare patience. My GT is approaching 110K miles so I know I'll need help frequently. I hope I can return the favor of whomever's advise throughout time.
With that said, I have two issues.
  • My driver's side window does not work. The motor still works and it is still on track, but does not move.
  • my air went out but only for about an hour. Is this a switch thing?
Thanks in advance for any help,
Andy
Old Jul 10, 2004 | 10:15 PM
High_Horse's Avatar
High_Horse
Could you be a bit more specific on the vehicle. Year, model and such would be helpful. Give a good description, engine size, things like that.
As for the Air going out, what do you mean? Did it go out while driving, does the fan still work, again specifics and info are very beneficial.
When your writing just remember we can't see or hear your problems, so description is important for assistance.
Old Jul 11, 2004 | 02:22 PM
LxMan1's Avatar
LxMan1
Sounds like the window gear inserts are bad. Pretty common on Ford power windows.
And, yes, more info on vehicle, engine, etc is a big help in identifying problems.
Jimmy
Old Jul 11, 2004 | 07:09 PM
amalivuk's Avatar
amalivuk
yeah, sorry bout that. Thanks for the advice.
'98 GT 4.6
  • The air issue - the fan still worked so it was blowing air, just not cold air...just to remove all doubts, I did check to make sure I had it on A/C setting. It worked when I started the car but after a few minutes, it started blowing warm air. Later that day, after driving for a few minutes, I decided to check it again and it worked fine. That was Friday and so far it's remained functional. Because of this, I'm not in a dire situation but obviously something I need to check out before I'm stuck in the Central Florida summer without air.
  • Window - I can hear the motor working when I engage the button and I am able to pull the window up and down manually since it is still on track. I read somewhere that the motor turns a armature which turns a gear within the box. The gear has three nylon barrel shaped components which causes the unit to engage the window apparatus. Evidently the nylon barrels shatter eventually and the motor spins away and does nothing. The article recommended purchasing an aluminum rod that is 3/8" in diameter, carefully cut three lengths of that rod to be the length pf the previous nylon barrel and assemble the motor/gear assy rather than purchase a new or used motor assy.
Just wanted someone else's thoughts before I start taking my door apart. Many of my friends own stangs but they bought the new motor when encountering this issue.
Thanks in advance for your thoughts,
Andy
Old Jul 11, 2004 | 09:00 PM
High_Horse's Avatar
High_Horse
The A/C issue sounds like a recharge scenerio. If the system has never been serviced, it may need a new orfice tube and such.
The window situation I believe falls into LxMan1' turf. Personally I would just replace the drive motor.
One suggestion, I would buy a Haynes book ($11), its very good at details in removing and replacing most anything on your vehicle. Its saved me a lot of mechanics bills.
Old Jul 12, 2004 | 03:35 PM
LxMan1's Avatar
LxMan1
I have done the 3/8" rod thing, it it kinda works, but the barrels are not exactly round and sometimes if the window is opened or closed too tight, it will lock up. AutoZone sells replacement gear kits for usually under $20 per window. I use these kits now, less hastle.
Jimmy
Sounds like either low refrigerant or possibly either a faulty a/c compressor relay or pressure switch.
Old Jul 17, 2004 | 07:47 AM
amalivuk's Avatar
amalivuk
Thanks guys! I bought a Haynes book and will buy a gear repari kit today. My pops said the same thing about the compressor switch.
I'll let you know how it turns out.
Thanks again!
Old Jul 17, 2004 | 05:46 PM
LxMan1's Avatar
LxMan1
The A/C thing could have been a stuck relay, or possible a failing pressure switch. If it is cooling good, I would doubt that it needs recharging. Sounds more like an electrical problem, such as a switch or relay.
95bronco302
1978 - 1996 Big Bronco
13
Jul 28, 2016 05:50 AM
1976GT
Dec 29, 2015 01:38 PM
xc4jokestomper
20
May 7, 2012 10:07 PM
86_cookiemonster
Dec 31, 2011 09:32 PM
>>OZZY<<
1997 - 2003 F150
Dec 16, 2010 09:12 PM
