302 4x4 build
-a pretty big cam
-port and polished gt40/gt40p heads
-port and polish stock intake
-hooker long tubes with full exhaust
-possibly a 3 angle valve job
-stage 2 B&M shift kit
thats the initial plan for right now because of budget. later on i plan on different roller rockers, bigger TB, larger injectors maybe, and a stall maybe.
im just wanting to do the above for right now and im trying to get together a parts list and decide on what cam and what set of heads.
im going to try and think long term meaning when it comes down to picking a cam and what not i want something that later on when i put on other parts i will still benefit. for example say i choose a cam that needs a stall or different roller rockers to make the most power but still makes an improvement over what i have now.
with all that being said what cam should i go with? i dont plan on replacing the rocker arms for the first part of the build this summer. how big of a cam can i get without havign to get different push rods and valve springs and what not?
also which heads should i go with? the gt40's or gt40p's? whats up with the p's? they dont have a hole for something? if thats smog related i plan to get rid of the smog pump and what not anyway.
im hoping some of you guys chime in and help me out. its going to be a somewhat budget build or i would not even mess with the 302 and just swap in a built 351.
But then a 351 has a substantially stronger block and already has the displacement you need so you have almost unlimited upgrade potential and can instead focus on the topend parts.. which all have to be replaced to reach full potential power.
But before getting too far into the motor we really need to know if your truck is mass air or not. If it is then you're good to go but if not then you are going to be severly limited in what you can do without a mass air conversion, and that isn't a small problem because you also have a computer controlled transmission.
What type of rockers does my truck have now? I was planning on using those on the gt40's.
All the head work was going to be done by a friend of mine so their wont be much cost there at all hopefully.
Conanski the biggest tired that will ever be on my truck will probably be 33's possibly 35's but for now I'm sticking with the 31's for a few years. I will look into a stroker though. My main reasoning for my initial plan was to keep costs down but I've never really looked into a stroker either so I will do that later tonight. But for now I would really like to stick with the 302 I already have.
I don't quite understand the whole rocker thing that fungus has mentioned? If I get too big of a cam will I need a different type? I'm not really wanting to go with an aftermarket rocker set yet.
You're getting headers so don't worry about the difference in width of the 351.
Gt40 heads. If you get p heads make sure your headers work with the strait sparkplug. ( that's the difference between p and non p heads)
Port and polish the heads. And get larger valves put in them. Get the valves online and it will save tons of money.
Swap in a 351. It's not hard. Other then flywheel/flexplate, everything is the same. The acessories bolt to the heads, so width isn't an issue again.
eBay has cheap 393 stroker kits that are balanced already. For quick bolt in CID.
Don't worry about what people say about crappy head flow. Your only gonna rev this thing to 5k. They will be plenty for what you want.
Get a mustang (lightning) style 351 intake and tb
30lb injectors
80mm maf
Go get a custom chip made for the truck and have a fun driver that will do whatever you want.
I wish I had the 4r70w. I love that trans. I'm stuck with sd and e4od. I'll be doing exactly what I just told you.... Soon as I get that econo dd car like you just got.
Given this is supposed to be a budget build I'm gonna caution you about sinking any serious amount of money into GT40 heads, it's real easy to blow a lot of $$ with bigger valves and porting and all that and that's not money well spent, unless your friend doing the porting has a CNC milling machine he simply isn't going to improve them much and for a little over $1000 you can have fully assembled RHS or Dart iron heads that will outperform your fully ported GT40s by a mile.
Concerning the intake what you're going to find is that's it's really pretty good as cast, the only portion that really needs attention are the exits of the ports in the lower section, these narrow down the last inch or so before the gasket surface and become a choke point so port matching(not gasket matching) them to the heads is recommended. But otherwise these ports flow about 200cfm as they stand and it's not hard to get upwards of 250cfm with a little work and that will exceed even the most expertly ported GT40 heads. The stock twin throttlebodies are also equavelent to a 75mm single which will support 450hp so you also have lots of room to grow there without spending any money.
Another thing to note is that with the 302 most of the extra HP is above 2500rpm so appropriate axle gearing is an integral part of the package, for a truck with 33's you should have 4.10's minimum and 4.56's wouldn't be out of line. That also means that the cam should target that rpm range so I'd suggest the Comp 35-320-8, it "only" produces 0.512" lift with the stock 1.6 rockers but that's more than sufficient to get 100% from the heads so there's no need to use 1.7s. This cam also leaves you room to grow with the potential for 350-400hp with better heads and a stroker kit down the road, and it should make every bit of 300hp with GT40 heads.
With that cam you mentioned would I need to replace anything else? Will the springs and everything else be okay? Do you recommend I replace anything else while I'm in there?
I have all the tools and equip to do this in my shop.
And with access to a water jet, flanges are quick.
Building turbo manifolds are a day job and welding it is another few hours.
As far as cost... eBay is my friend. Turbo is 100-150. MSD btm is affordable and the fmu is cheap last I checked.
Or porting heads, afternoon job. Stainless Valves are around 110 and the machine shop charged me 250$ last time I had them put in.
Really as far as power for money. Buy a 351, swap the cam and be done. It's only the extra cost of the motor and if your not gonna build a stroker motor, your setting yourself up for disappointment. I already have a 351 and I'm disappointed. At least you're ahead and have mass air.
also i got on camquest and what about the comp 35-552-8? it has less lift but a tad bit more duration on the exhaust side i believe.
