Modular V10 (6.8l)
Coil on Plug corrosion
Old Jul 3, 2004 | 07:59 PM
Rambler's Avatar
Rambler
When I bought my '99 V-10 used it had a coolant leak that dripped on the nr 6 - 8 - 10 coil-on-plugs. I tightened a heater hose clamp to stop the leak but later discovered corrosion in the electrical harness to coil-on-plug quick disconnect fitting. I was able to clean the male side of the plug but am wondering if there is a tool available to clean the female side of the fitting. I tried cutting down an electrical spade to fit in the slot and sprayed it with electrical contact cleaner but still need to find a way to better clean the female side of the fitting.
SQUIRMIN VERMIN
1997 - 2003 F150
Jun 24, 2014 05:40 PM
Water_Boy
Feb 22, 2013 01:13 AM
hamiltonfighter
May 22, 2012 12:22 AM
PIXMA
New Member Introductions
Dec 29, 2006 08:27 PM
ejpreston
2004 - 2008 F150
Aug 15, 2005 07:41 AM
