aftermarket tachometer wire?
Old Sep 3, 2004 | 12:15 AM
ejpreston's Avatar
ejpreston
Alright, I fail to believe that the only way to get an aftermarket tachometer to work on our trucks is with that $90 plus "adapter" for a $30 tachometer! Has anyone figured out if/where the main engine RPM wire is (instead of the individual ones that go to each coil-on-plug)? Thanks.
Old Sep 3, 2004 | 03:22 PM
ejpreston's Avatar
ejpreston
anyone? I would think that since these trucks come with tachs as an option, there must be a wire somewhere....
Old Sep 3, 2004 | 04:27 PM
khendrix's Avatar
khendrix
Im sure that there is a while that goes to the Tach in the dash. SOmehow pop the dash back and splice into that wire.
Question though. Why would you want an aftermarket Tach if you already have one?
Old Sep 3, 2004 | 04:28 PM
khendrix's Avatar
khendrix
Never mind my last post. I didnt realze that you had a XL model. Never mind me.
I have no answer for you.
Old Sep 3, 2004 | 04:29 PM
skip #7's Avatar
skip #7
I got my tach driver from Jegs for 60 bucks put a mini in the dash in the change holder hole in the dash on my yellow stx scab,works great the driver is a ford part.
Old Sep 3, 2004 | 11:27 PM
HamRadio's Avatar
HamRadio
Thumbs up Kool
Mine came from JEGS too....I like where you put the tach. Mine went on the dash right next to the left window post, on velcro but now I might just move it to that useless change holder, yah! Thats the ticket!
Old Sep 4, 2004 | 01:40 PM
ejpreston's Avatar
ejpreston
That's exactly where I was thinking of putting it, except the column shifter gets right in the lkine of signt for me when in drive, so I'm thinking of switching the headlight switch to the change holder location, and putting the tach. where the headlight switch is. I'll look into the Jegs driver. Thanks.
Old Sep 4, 2004 | 01:46 PM
HamRadio's Avatar
HamRadio
True
Yes it is in the way, I found out this AM. The part you need to order from JEGS is made by Autometer. My tach is also an Autometer. Search the Autometer web site then order from JEGS.
Old Aug 14, 2005 | 09:57 PM
Nukem420's Avatar
Nukem420
What's the part# for the tach driver??????
Old Aug 15, 2005 | 07:41 AM
HamRadio's Avatar
HamRadio
AutoMeter part #9117
Enjoy!
redwood tree
Nov 26, 2024 11:56 AM
miashley150
13
Aug 22, 2013 11:34 AM
WetDog
2004 - 2008 F150
Nov 27, 2006 04:44 PM
mcne
Electrical Systems/Wiring
Feb 28, 2006 07:11 PM
aaron59
Aug 27, 2005 05:25 PM
