I'm new to COPs
Old May 21, 2012 | 07:15 PM
hamiltonfighter's Avatar
hamiltonfighter
I'm new to COPs
I have never had or worked on a vehicle that used Coil-on-Plugs. When searching on rockauto.com I saw that you could purchase a COP, which consisted of the boot and a spring. Or you could purchase the coils.
What is the difference between the coil and a COP?
Old May 21, 2012 | 07:21 PM
hamiltonfighter
Okay,
I'm looking through rockauto.com again and I might have answered my own question.
The first item under ignition is COP Coil Boot. This is just part of the coil, correct? Do the boots tend to go bad quicker then the upper portion a lot faster?
The other listing is for the whole ignition coil.
Any thoughts on COPs advertised for performance?
Thanks for any input.
Old May 21, 2012 | 08:34 PM
Eric H's Avatar
Eric H
The boots can become brittle and crack before the COP fails. This allows moisture in and leads to bad spark.
I fixed a rough running problem on my Excursion last summer by replacing the spark plugs and installing new boots. Mine were very brittle.
Old May 21, 2012 | 11:09 PM
wpnaes's Avatar
wpnaes
Assuming you're having a miss? It's best to replace all the boots with a dab of dielectric grease (cheap) and only replace the COPs that are bad (expensive). I've replaced only 3 in the 12yrs of ownership. Don't just replace all 10.
Old May 21, 2012 | 11:24 PM
hamiltonfighter
Not having a miss yet. I have a CEL with P0720, Output Shaft Speed Sensor.
Found several threads with mention that a coil going bad can cause the P0720 CEL. Saw that ebay had 10 packs of coils for $100. Thought about changing the COPs as part of a tuneup. I would play it safe and change the Output Shaft Speed Sensor too.
Old May 22, 2012 | 12:00 AM
gr8scott72's Avatar
gr8scott72
Spark plugs and coil boots - change as preventative maintenance.
Coils - if it ain't broke, don't fix it.
Old May 22, 2012 | 12:22 AM
hamiltonfighter
Cool, thanks.
DItR
Apr 25, 2017 02:43 PM
cgi2099
Dec 12, 2011 09:37 AM
njf207
16
Jan 13, 2009 09:25 AM
JASON11WS6
1997 - 2003 F150
Aug 9, 2007 10:42 PM
nicksgt
Modular V10 (6.8l)
Dec 28, 2006 11:55 AM
