So...
Old Jul 2, 2004 | 04:24 PM
bighoss550's Avatar
bighoss550
Originally Posted by Tim Lamkin
Sort of like a long block...less harness
a long block, PLUS harness, PLUS injectors and all the rest of the stuff...
basically, it would run right in the box it came in if u hooked up the wires veeeery nice way to do it...
Old Jul 2, 2004 | 04:54 PM
Choctaw Bob's Avatar
Choctaw Bob
That is probably the $15,000 engine mentioned on another thread.
Old Jul 3, 2004 | 05:15 PM
scjfox's Avatar
scjfox
Yup, thats probably the engine, swap the engine, hook up about 3 connectors and youre ready to roll. But like bighoss said, they come with oil and probably have been dyno'd! lol....
On the vibration, only reason I rule out the converter and flywheel is because the way this formula and the tool work, you use the o.d. of the diameter to figure whats vibrating. Its pretty hard to explain, but I could be wrong, havent had this problem before, so Im sure Ill learn from a mistake
Old Jul 3, 2004 | 06:00 PM
bighoss550's Avatar
bighoss550
so the tool reads the fore and aft vibration, instead of just one
Old Dec 4, 2004 | 04:02 PM
oelc's Avatar
oelc
that is what I just put mine in for and my dealership replaced an injector. at one point stuff in my console was bouncing out, because vibration was so bad. I would tell you that this fixed the problem, but I did not get a chance to drive more than a mile when I realized that something else was wrong and I had to take it back to service.
trip one.... hesitation and exhaust in cab
trip two.... huge vibration from motor
trip three... squealing noise from engine
thank you sir, may I have another
Old Dec 4, 2004 | 05:21 PM
04powrstrokr550's Avatar
04powrstrokr550
when our first motor blew, it was replaced with a whole new "turbo to oil pan" motor. then the same problem happened again 7000 miles later, (same cylinder same side-effects). now theyre dropping another turbo to oil pan in.....
they still dont have the problem fixed- they put a new wiring harness and injectors in ( the works), but the same problem is showing up again. it may be a coinidence, but its highly doubtful.. anyone know what may be causing the problem outside of the ECM or wiring harness?
Old Dec 4, 2004 | 09:37 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
7.01.04 is when this thread started...how did you find this one?
justin30513
Feb 6, 2010 11:16 PM
ftowelding
Aug 26, 2008 04:26 PM
88grandmarquis
20
Jan 7, 2008 06:27 AM
hoxiii
Engine Swaps
Aug 7, 2006 01:19 PM
88grandmarquis
40
Dec 8, 2004 11:39 PM
