shaving
Old Dec 2, 2004 | 05:35 PM
88grandmarquis's Avatar
88grandmarquis
shaving
Looking for some input.
What is preferred: electric or manual razor?
The job I work at doesn't really care too much about appearance, so I usually just trim my beard. I may be getting a part-time job on the side that does care about appearance. I avoid shaving with my electric shaver (Remington) due to the fact that it itches like crazy afterwards. I've never used a manual razor and I'm wondering what the opinion is on it. I figured I would ask before going out and buying, to save a little cash. Any brands better than others?
Thanks.
Justin
Old Dec 2, 2004 | 05:44 PM
1BigExpy's Avatar
1BigExpy
Both, Apply preshave use electric razor. After that a quick drag of a cheap disposable and I'm done. Being a military man appearance counts and this method has worked for me for the last 12 years.
Old Dec 2, 2004 | 06:13 PM
wlihntr's Avatar
wlihntr
hand held razor(electrics make my face break out)i love my new gillett mach 3, much easier to keep clean than my old attra
Old Dec 2, 2004 | 08:40 PM
13MWZ's Avatar
13MWZ
I've tried the expensive 2, 3, and 4 blade razors, but they've all been a waste for me. I get my best shave from a regular ol 2 blade disposable razor. I usualy get them blue Gillet ones.
I tried an electric one once but didnt like it. It didtn get close enough.
Old Dec 2, 2004 | 09:01 PM
Howdy's Avatar
Howdy
I get out of the shower and scrape away. Tried shaving cream once, but took too long and was a mess.
Old Dec 2, 2004 | 09:06 PM
Matts72's Avatar
Matts72
Razor for me... Mach 3... pretty spendy but does a good job and its not irritating. I use Nivea shave gel....
I did try an electric once, thought it better for the garbage than my face...
Old Dec 2, 2004 | 09:12 PM
FFOORRDD96's Avatar
FFOORRDD96
the Gelette Sensor Excel Is The Best Razor I Dont Like The Mach3
Old Dec 2, 2004 | 09:21 PM
RodbusterGS's Avatar
RodbusterGS
I use Gillette Mach 3.....works well.....The blades are expensive, but I got a good piece of advice from my grandfather a couple of years ago: When you are done shaving, wash the razor out real good and then soak the blades in a cup of baby oil. I can get about 15 good shaves out of each blade before I notice them getting dull
Old Dec 2, 2004 | 10:44 PM
Proteus566's Avatar
Proteus566
My razor of choice is a Mach-3, I far prefer it over the disposables. I also use the Gillette shaving cream, and Old Spice after shave.
I used an electric at my friends one time, and didn't care for it to much. Since I had to go over it again with my Mach-3.
Alvie.
Old Dec 2, 2004 | 11:03 PM
maticuno's Avatar
maticuno
I use the Mach-3 to get down to skin, and I use an electric Remington beard trimmer to keep my goat trimmed down.
Old Dec 2, 2004 | 11:46 PM
rebel_ford4x4's Avatar
rebel_ford4x4
i use the cheapo gillette disposable razors, they work good enough for me and i use barbasol shaving cream, also cheap but does the job.
Old Dec 3, 2004 | 12:17 AM
superspike's Avatar
superspike
If you're going to shave with disposable razors, get ones that you can replace more often (inexpensive ones) so that you don't get bacteria buildup that can cause infected hair follicles.
Old Dec 3, 2004 | 01:07 AM
ford57trucker
Guest
Posts: n/a
you guys should have had to shave with old gillette blue safety razors. when i started shaving that's all there was. new, they were like a an old worn out disposable razor then it went downhill from there.
Old Dec 3, 2004 | 02:22 AM
grease monkey's Avatar
grease monkey
I use the mach 3 that thing is great the blades are not cheap though but it is the closest shave I have yet
Old Dec 3, 2004 | 03:39 AM
RR4E's Avatar
RR4E
I've used a straight blade, hunting knife(in desperation, with a razor sharp edge mind you) various disposable and replaceable head type razors and a couple or three different electrics. Electrics are fine as long as you shave everyday, and apply after-shave, but it really depends on your skin. Sensitive skin tends to not like the electric much, and will break out. Electrics don't shave nearly as close as a blade, or disposable. I tend to not shave as often now, as I don't personally care if I look like grizzly adams, and work a night-shift where no one really has to see me anyways. My preference lies towards the disposables(higher end) or a middle of the road replaceable head unit. I change blades after every shave, sometimes use more than one for a shave, but the blade still rules for me.
