Carb or Fuel injection??
Old Jun 26, 2004 | 04:28 PM
FORD_LOVER's Avatar
FORD_LOVER
I have a 1986 Ford F-150 with a 302 with stock EFI. I'm considering changing my fuel delievery system. Would it be smater to go with a new manifold and carb or a new Fuel injection system. I don't do serious off-roading, just looking for the most powerful and reliable option. Please leave your suggestions and reasons why.
Old Jun 26, 2004 | 04:31 PM
freak98's Avatar
freak98
I'm for the carb.I like being able to tune my engine wothout having to use a laptop.
Old Jun 26, 2004 | 04:53 PM
rusty70f100's Avatar
rusty70f100
I'm for the fuel injection. I'm like tuning my engine without having to take things apart and buying gaskets every time I make a change.
Old Jun 26, 2004 | 05:50 PM
ratstang's Avatar
ratstang
What is wrong that you want to change the fuel delivery system? The smartest thinkg might be to fix the current FI setup.
Old Jun 26, 2004 | 06:11 PM
FORD_LOVER's Avatar
FORD_LOVER
What kind of upgrades are you looking at. As far as I know there is very little to mess with and get decent power.
Old Jun 30, 2004 | 10:26 PM
MustangGT221's Avatar
MustangGT221
https://www.ford-trucks.com/forums/s...d.php?t=232879
Posted a little while ago.
Old Jul 1, 2004 | 02:09 AM
mako5972's Avatar
mako5972
I would stick with the fuel injection. You get better fuel economy through precise metering of the fuel. Less emmissions. I wish my engine had fuel injection.
Old Jul 1, 2004 | 09:06 AM
Mike G's Avatar
Mike G
..and speaking of emissions, are you in a state that will not let you make the change to carb? Will you have inspection/testing issues if you remove the current system?
--Mike
Old Jul 1, 2004 | 05:58 PM
f100guy's Avatar
f100guy
you can tune a carb to produce less emmissions like the efi does
Old Jul 7, 2004 | 12:30 AM
MustangGT221
Um, I beg to differ. A poor running EFI system maybe...carbs won't even come close to SEFI (sequential), and I bet it won't come near a regular multi-port either, so i disagree.
Old Jul 7, 2004 | 05:01 PM
f100guy's Avatar
f100guy
not from what i hear from many around this site and others
Old Jul 8, 2004 | 12:23 AM
MustangGT221
Well...then why are all new cars EFI for better emissions...why arn't they still carbs if they can get better emissions....
A carburator is not as efficient as an EFI engine. The SEFI (sequential fuel injection) is the most efficient. I'm honestly blown away that you're saying this...but its too late for me to explain right now.
But you're trying to say that a carb...which sprays fuel and air through the ports of an intake and is sucked into an engine, is capable of being more efficient (which is what results in lower emissions) over an EFI engine which sprays (under high pressure, more efficient) the fuel right at the back of an open (hot) intake valve (way better atomization)? And the fact that it's perfectly metered fuel for a correct air/fuel ratio at all throttle positions, rpms, and loads? I think not, and so do many respected engine builders in the..oh..maybe 6 engine books I've read in the last couple months.
I'm not trying to be argumentative and offensive, but this shouldn't even be debated.
Old Jul 8, 2004 | 11:15 AM
f100guy's Avatar
f100guy
i'm just saying what i hear
pti
Jan 12, 2016 03:23 PM
dlanders71
Apr 16, 2013 09:31 PM
83shotbed4x4
Feb 16, 2004 06:47 AM
tturvy
Sep 29, 2003 04:06 PM
tmcgin
Dec 18, 2001 06:49 PM
