calling all fuelie experts!!
Old Feb 15, 2004 | 12:55 PM
83shotbed4x4's Avatar
83shotbed4x4
i am putting a 351W into my currently 300ci powered 83 4x4. my question is, the 351 is fuel injected. what should i do find a new intake and install a carb, or install the fuel injection? now, i am dead in the brain to the fuel injection of the ford v8 will i need a computer brain or what will i neede to do to keep the 351 fuel injected. any helpwould be awsome thanks!!
mike
Old Feb 15, 2004 | 04:47 PM
EPNCSU2006's Avatar
EPNCSU2006
It would probably be easiest to just swap out the EFI manifold and front cover in favor of carbureted units. The fuel injection is possible, but it would require some wiring on your part, although it shouldn't be too difficult if you wanted to go that route. You would need a computer and complete wiring harness for sure. You would also need to somehow rig up a high pressure fuel delivery system, as well as a return line to the tank(s). Might be easier on an truck originally carbureted to stay with a carburetor just for simplicity's sake. Not saying that EFI can't be done by any means, but carb'd would be easier.
Old Feb 15, 2004 | 05:02 PM
83shotbed4x4
that's what i expected. what front cover are you talking about that i will have to swap? also what type of manifold will i have to install? will a normal carbed 351W manifold fit? i know i will need to install a fuel pump. oh yeah, what about the distributor?
Old Feb 16, 2004 | 06:47 AM
EPNCSU2006's Avatar
EPNCSU2006
The timing chain cover (front cover) for a carbureted engine has a mount for the mechanical fuel pump, and is set up for a standard rotation water pump. Any 351W carbureted intake manifold would work, and there are a couple things you can do for a distributor. If it's just going to be a stock engine, you can get a stock replacement distributor and run a duraspark type ignition. Or you could get an MSD distributor and run a 6 series ignition box with it if the engine is going to be more performance oriented than stock. We're getting away from what I know about when we start talking carburetors, so I'm not going to be much help with that aspect. Someone else can probably give you a better idea of what you will need ignition wise.
bluff3
Apr 21, 2016 09:18 AM
coldsteel187
Sep 8, 2010 11:48 PM
egmeyer
Nov 10, 2007 07:02 PM
Psyte
Feb 2, 2006 10:17 PM
laros
May 27, 2002 02:32 PM
