Carburation vs. Injection
Old Apr 22, 2004 | 03:19 PM
wezol5484's Avatar
wezol5484
Id like to know the pros and cons of carburation vs injection. Pros and cons of hp and tuning with each. Me and a friend were arguein over whether carburators could gain more hp or injected could gain more. So who better to ask then yall here at FTE, my friend drives a chebbie too just so yall know lol.
I say carbs he says injection.
Old Apr 22, 2004 | 03:21 PM
nick88f150's Avatar
nick88f150
....ive been wonderin the same thing, cuz if its worth it i wanna convert my 88 EFI over to carb, if thats even possible
Old Apr 22, 2004 | 03:50 PM
wezol5484's Avatar
wezol5484
Hey mods I put it in Gen Auto cause I know alot of people linger around there and I wanted to get as many opinions as I could. My friend is prob gonna get a 350 this weekend to drop in his camaro and he doesnt know whether he wants injection or a carb so I was tryin to help him out. Do you think we could leave it there for a few days? PLEASE
Old Apr 22, 2004 | 03:51 PM
MustangGT221's Avatar
MustangGT221
Fuel injection is a lot more efficient and is capable of making more power that a carburator, but it depends on which type of EFI.
The TBI (throttle body) injection is not much more than a carb as the intake is a wet system (gas and air are going through intake). You see that on older chevy's (late 80's). The ford system is either multi-port (speed density 87 through 95ish) or Sequential (MAF 95-96sih). Those years are for the trucks, cars were different. The ford system has injectors right infront of the intake valve which helps atomization. The fuel can actually hit the back of the hot intake valve and create great atomization (more power).
The pros of carbs are that they are cheap, easy, simple, and reliable. EFI is expensive and complex but if the person does enough research about EFI than EFI is just as tunable.
You could not get a 500hp carb equipped motor to drive you to the office comfortably every day. EFI opens the doors to all kinds of possibilities. You can make 500hp and drive it to work everyday and have it idle nicely in traffic..etc etc.
EFI is much more efficient which will make more power and better gas mileage as well as lower emissions, ceterius parabus. Some racers still use carbs for their cheapness and reliability because they'd pretty much need a custom EFI system which isn't cheap. Most well sponsored racers (depending on what kind of racing) use EFI.
No offense but it would be stupid to convert a stock EFI truck back to a carb. I've recently done a lot of research on EFI systems and Ford's EEC-IV with SEFI MAF is one of the best EFI's out there and you can make some really nice power out of it. EFI also has great throttle response and can run at any angle. Ask a hardcore offroader how much they hate having a carb in off angle situations (causes the motor to die). Now there are exceptions to this, like a well tuned carb can out perform a poorly setup EFI system, but the general rule of thumb is that EFI is better. There is a reason why even my snowmobile now has EFI over a carburator, it's simply better overall.
On edit:
You'll get a better response here because the people who hang out here know what they're talking about. Hopefully my answer did the trick. Look here if you havn't already...https://www.ford-trucks.com/forums/s...d.php?t=212967
Old Apr 22, 2004 | 04:07 PM
wezol5484's Avatar
wezol5484
Thanks mustang ya that explained it well.
Old Apr 22, 2004 | 07:12 PM
nick88f150's Avatar
nick88f150
i agree with him thanks for the info...if fords efi is one of the best, ill keep it, i just thought id switch cuz id have a better shot at tuning the carb, but ill find a few books and read up
Old Apr 22, 2004 | 10:53 PM
MustangGT221
Motorhaven has some great books on Ford's EFI...check em out..I have 6 of them
http://www.motorhaven.com/customer/home.php?cat=141
Old Apr 25, 2004 | 12:46 AM
pizalm's Avatar
pizalm
If carbs were better why do high performance vehicles, like ferraris, today run EFI?
ccllud
Aug 22, 2021 03:30 PM
Kyle Wood
Mar 30, 2017 06:31 AM
stevenconrad66
Nov 30, 2016 09:52 AM
Alek Merkoulov
1978 - 1996 Big Bronco
Mar 3, 2016 04:48 PM
lisagoud
Sep 11, 2006 05:36 AM
